We make transformer which current is big, we often use copper foil and heavy lead out wire, first we solder lead out wire, strip insulation lacquer first, keep heavy diameter wire flat, solder them using big power iron,enough solder, control soldering time and flux, can not fake soldering,soldering point is with enough tin and brightness, pull force testing is necessary , in general, it is process technology question, thanks!
