Thanks Armadillo and DC1MC. Drift is on amplitude level.
Haha, pretty low opinions of BK on that link DC1MC. Spot on though as I am also working through Learning the Art of Electronics. Schematic from BK is attached but it's a poor scan of a 1995 drawing so difficult to see what's what. Power supply is integral, not external.
No warranty as got it second hand (shipping and customs from USA to UK cost as much as the base price).
OK, the schematic is bad but usable in an emergency, stick a scope on the Level adjusting potentiometer R300, both on the cursor and on the input and look at the output level, if the level stays fixed on the input, then focus on the cursor's level, if both are stable then the output amplifier is out of question, if the potentiometer input is stable, but cursor fluctuates, check the potentiometer.
But if the input signal amplitude is unstable coming from the oscillator, than you're in a lot of pain, there are like a brazllion of switches, potentiometers and stuff to clean and verify, first check the +/- 22V power supplies and also +/-15V, you have an RC oscillator there, and it's not unheard of to have amplitude drifts if the power supplies are noisy or drifty, if the voltages seem OK please also use your scope on DC coupling and check the ripple of the PS as well, sometimes, due to component failure, when going from cold to warm, there are drifts and noise shown up. IF you have some analogue meter, put it on each power supply in turn, cool off the generator and let it warm and reproduce the output level drift while checking the power supplies values.
Cheers,
DC1MC
