What is CR? Is the part number of CRT?
CR1, CR2, CR3, CR4, CR5, CR6, CR7 are the bridge rectifiers on the power supply board schematic.
I did see that some rectifier bridges,are very hot.I dont know the regimen of those rectfiers.
What is the CR number of the hot rectifier bridges on the power supply board?
It shows me exactly -1832V
This cathode voltage is too low. Measure the +120 Volts on the HV power supply. And check that the "Deep Erase" switch on the rear panel is set to "Normal."
About the -1832 Volts, here is what I think. Look at the HV power supply schematic. See where the tap on the HV transformer secondary (pin 7) is less turns than the end of the secondary that becomes -2295 Volts with CR3?
If the +120 Volts is good, and the tripler is defective, the tripler may be loading the HV transformer and pulling the CRT cathode voltage down. Disconnect the lead to the tripler, from this pin 7 of the HV transformer. Measure the CRT cathode voltage again. Is it still -1832 Volts or is it now close to -2295 Volts?
