Author Topic: MiniPro TL866 Firmware Upgraded and broken Fake device  (Read 8503 times)
Offline Mikek400Topic starter
  • Country: jp
« on: April 20, 2016, 06:31:06 am »
Got a Mini Pro today. Installed software and software told me to upgrade firmware.
After upgrading got error and then application gave me this message (see pic below)
This sucks.. Been waiting for this thing for 2 weeks and breaks in 5 mins.
« Last Edit: April 20, 2016, 07:10:45 am by Mikek400 »
Offline Kilrah
Re: MiniPro TL866 Firmware Upgraded and broken Fake device
« Reply #1 on: April 20, 2016, 07:54:14 am »
Welp... buy a real one next time?
  • Country: jp
« Reply #2 on: April 20, 2016, 10:54:58 am »
I thought it was a real one...   Box and description said it was.. Heck even looks the same on the inside as the one Dave tore down.
The application erased the firmware on the device so I am going to try to reprogram the PIC on the board.
« Last Edit: April 20, 2016, 10:56:54 am by Mikek400 »
Offline macboy
« Reply #3 on: April 20, 2016, 02:29:10 pm »
I've programmed mine with a PicKit3. The PCB has holes for the standard ICSP header inside. I didn't even solder a proper header, I just press-fitted male header pins into the PCB holes while programming. Good luck.
  • Country: jp
« Reply #4 on: April 20, 2016, 04:57:38 pm »
 :) I found a PDF and Application from radioman's PDF and software in the blog post about this programmer.
 https://github.com/radiomanV/TL866
Reprogrammed it using a parallel port,  :-/O  some resistors and the attached pdf and software.
I attached the PDF files and the application below for reference.
« Last Edit: April 20, 2016, 08:34:17 pm by Mikek400 »
The following users thanked this post: ebclr, james38
