I've ordered 5m each of the red & black 14AWG silicone sheath wire. Total US$20.91
http://www.aliexpress.com/item/14AWG-Black-5M-Flexible-Silicone-Wire-Cable-Soft-High-Temperature-Tinned-copper-UL-VW-1/32432300722.html
When it arrives in a few weeks I'll let you know if it's any good.
Wow, that was quick! It arrived today, 8 days after ordering. And it's *very* nice.
- The 14AWG copper thickness gives it a good weight,
- It's very flexible so the weight makes it flop down and stay put,
- The surface has just the right amount of inter-wire friction to neither snag or slip around,
- It feels pleasant to hold,
- The silicone insulation is thick enough that it seems safe for test leads (measured: 0.9mm)
- The core solders very easily,
- The insulation ignores soldering heat,
- It's labeled unobtrusively with what it is - "14AWG 200 Deg C". No annoying advertising.
- No more mentally subtracting something between 0.3 and 1.5 ohms from resistance measurements.
Ha ha.. Clipped my Fluke 77 leads to the ends of one of these 5m lengths. Reads 0.3 ohms. Keeping that attached, short the two clips together. Zero reading change. (The 0.3 ohms is all in the existing multimeter leads. Which are relatively 'good' ones.)
- Typical Chinese entertaining creativity in the customs declaration. "Insulation tube" indeed.
- Lastly, it's cheap enough. $21 for 10m plus postage.
This is wire sent down to us from his noodliness.
Can see I'll be buying more of this in other colors too.
Now for the probes, clips and plugs.
