If you can, use central climate control. I have a whole house humidifier with a humidistat which ranges from 10% to like 95% which I usually keep around 48% to no more than 60% depending on the needs. This is just enough to keep static to a minimum. The central AC in the summer will dry out the humid air, but you may need to still run a humidifier depending on the efficiency of your AC system. I have various temp and humidity gauges around the house for monitoring so I can try and keep things at a nominal temp/humid. I also use a moisture meter to check floors, walls, carpet, benches, tables and furniture from time to time. I know that sounds extreme, but I lived in a house years ago that had no climate control and after 10 years it ruined quite a few items including some camera equipment and personal memories stored away. Anything above 70% humidity, mold starts to grow. This can affect health and damage property. Also, if you read your specifications thoroughly as I do, the relative operating humidity of most equipment is no more than 80-95% humidity max unless it is rated for high moisture environments. Personally, this is what I do, and I am just sharing this to give you an idea as to what others may do. In general, I try to maintain an optimal environment all year round, I firmly believe this enhanced your health and preserves your property and delicate memories.
