Author Topic: Any resin gurus out there that can point me in the right direction. Bad prints.  (Read 8158 times)
Offline magnetchiefTopic starter
Hi, I have a Photon Mono X printer that I just can't get to work correctly.
Attached are a couple of photos showing my issue.
The print is not detaching from the screen.
I have tried running through the set up a few times all with similar results.
Also attached a photo of identical prints on my Form 3. These work perfectly, but of course at a much higher cost.
The Mono X was purchased to make quick prototypes but it's just not working out.
Any advice greatly appreciated.
Online Mechatrommer
  • Country: my
  • reassessing directives...
1) maybe uv light is not powerful enough you need to increase exposure time by a bit?
2) maybe the bed is too sticky rubbing a thin layer of grease or some oily thing on it before print may help?
The following users thanked this post: magnetchief
Many thanks, will look into that
Offline eliocor
    • rhodiatoce
too low exposure...
Use UVtools and follow the hints in this video:
« Last Edit: June 22, 2022, 08:37:59 pm by eliocor »
Thanks, that’s an interesting link.
I’ll play around with the UVtest as per the video and try again.
Offline lugaw
  • Country: jp
Your FEP film is probably low grade, it shouldn't stick to the film.
FEP film now replaced.
I agree the one that came with the printer was pretty poor quality.
Offline amwales
I'm curious, did replacing the FEP fix it?
Well I experimented with UVtest and with that and the replacement FEP film I'm up and running.
Now recent issues, I can pretty much have the confidence to print as needed without issues.
