Author Topic: Geeetech MeCreator2 firmware wanted!!!!  (Read 11515 times)
Offline RefrigeratorTopic starter
  • Country: lt
« on: February 13, 2025, 07:42:34 pm »
I had a perfectly good mecreator2 and made it print nylon but the max temp settings were getting in the way.
So i found a github repo from some guy who had the marlin source apparently.
Downloaded it - didn't compile.
Spaghettied the config files into marlin 1.1.9 - compiled after fixing.
Uploaded to printer and it's bricked now. :-BROKE
No problem because the manufacturer has a download link aaaaaaaand it's 404. :bullshit: :bullshit: :bullshit:
So now i'm stuck with a printer that won't work and no way to reflash the original firmware.
Before killing it i did save the original boot message:
start
echo: External Reset
Marlin bugfix-2.0.x
echo: Last Updated: 2018-01-20 | Author: (Phr3d13, MeCreator2)
echo:Compiled: Mar 19 2019
echo: Free Memory: 3872  PlannerBufferBytes: 1376
echo:V64 stored settings retrieved (583 bytes; crc 31558)
echo:  G21    ; Units in mm (mm)
echo:  M149 C ; Units in Celsius
echo:Filament settings: Disabled
echo:  M200 D1.75
echo:  M200 D0
echo:Steps per unit:
echo: M92 X80.00 Y80.00 Z400.00 E100.00
echo:Maximum feedrates (units/s):
echo:  M203 X250.00 Y250.00 Z400.00 E45.00
echo:Maximum Acceleration (units/s2):
echo:  M201 X2000.00 Y2000.00 Z100.00 E10000.00
echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
echo:  M204 P2000.00 R2000.00 T2000.00
echo:Advanced: B<min_segment_time_us> S<min_feedrate> T<min_travel_feedrate> X<max_x_jerk> Y<max_y_jerk> Z<max_z_jerk> E<max_e_jerk>
echo:  M205 B20000.00 S0.00 T0.00 X7.00 Y7.00 Z0.60 E50.00
echo:Home offset:
echo:  M206 X0.00 Y0.00 Z0.00
echo:Material heatup parameters:
echo:  M145 S0 H205 B60 F0
echo:  M145 S1 H240 B100 F0
echo:PID settings:
echo:  M301 P33.22 I4.22 D65.31
echo:Linear Advance:
echo:  M900 K0.11
echo:SD card ok
And all i wanted to do was to increase the max temp to 290oC :palm: :palm: :palm: :palm:
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
  • Country: lt
Re: Geeetech MeCreator2 firmware wanted!!!!
« Reply #1 on: February 13, 2025, 08:06:59 pm »
Ok so turns out i was being dumb by trying to upload an old version of marlin, because the new version does have a config for my printer  :palm:
Just turns out that the config folder is now located entirely elsewhere, hence why i couldn't find it.
Case closed  |O
