@MarkF, great work!
The model is ready to use right now. It looks good and fits securely.
However, it's worth making two necessary adjustments:
- the hooks need to be moved so the part fits 1.2 mm higher;
- the hemispheres need to be trimmed to a height of 0.5 mm.
Here you can see how I cut out the hemispheres:
Here you can see that the part becomes 1.2 mm lower than required:
Photos from different angles:
