Author Topic: layer shifting  (Read 5097 times)
Offline HobGoblynTopic starter
layer shifting
« on: August 08, 2021, 01:57:09 pm »
Hi all, printers been perfect all year, then I changed main board to skr 3e mini and tft3.5. must have knocked something in the process as I now have layer shifting grrr.
Attached is a closeup of 4 sides of a chep calibration cube that I stretched to 60mm in the Z direction (wanted something quick to print)
Also attached is a closeup of spice jar rack I was trying to print first, printers been fine  been perfect before this.
Should I be looking at the X axis to fix this please?
Many thanks
Offline AmnevaR
  • Country: ua
Re: layer shifting
« Reply #1 on: August 08, 2021, 03:20:40 pm »
Hi, I'm not an expert, but I think that something is loose on the X axis (assuming it's a cartesian type printer) . It could be something easy - like the belt isn't properly tensioned or the grab screw that holds pulley on the motor is loose.
The following users thanked this post: HobGoblyn
Re: layer shifting
« Reply #2 on: August 09, 2021, 01:58:15 pm »
Thanks, checked the belt and the wheels, all seems OK, as it only happened after replacing the main board, I decided I was going back to the old one.
But I stupidly got black smoke to appear on old board grrrr  (thread in repair section).
Should have left it alone lol
Offline Microdoser
Re: layer shifting
« Reply #3 on: August 15, 2021, 09:09:06 am »
Layer shifts and ghosting are problems caused by your print speed being too high
