Author Topic: altium 19 component search / libraries  (Read 1740 times)
Offline vixoTopic starter
« on: March 31, 2020, 02:12:05 pm »
Ive been using Altium 19 recently and having a little trouble with the component search system - I used altium 16 before and the search was relatively fast and easy, but altium 19 the search function (in schematic - place part - file based libraries search) is very slow and slows the whole computer down while it runs, it also doesn't give any indication which library it's searching like it did in Altium 16, so you don't have any idea how far it is through the search AND it doesn't give you any option to stop the search like it used to.
Am I missing something? I feel like I am supposed to be using this in a different way because this is not working well at all. The speed thing I guess might be an issue with the computer or the setup, but I can't wrap my head around the other things
Offline ddavidebor
    • Sideband
Re: altium 19 component search / libraries
« Reply #1 on: March 31, 2020, 02:22:13 pm »
Hello,
Are your libraries on a fast drive? (SSD)
How many libraries do you have?
Currently working on the future of Altium library management https://getsideband.com/
Need Altium Designer Libraries? Check out https://getsideband.com/libraries (35k symbols, 34K footprints)
« Reply #2 on: March 31, 2020, 02:37:55 pm »
they're all on the local SSD. There are about 130
Offline ddavidebor
    • Sideband
« Reply #3 on: March 31, 2020, 07:42:37 pm »
Are any of the SVN or DB libraries?
Offline thm_w
  • Non-expert
« Reply #4 on: March 31, 2020, 08:28:25 pm »
You can try blocking altium in the outgoing firewall and seeing if that speeds it up at all.
Under win10 open Resource Monitor, go to Disk tab, select Altium exe. Then it will tell you what files it is accessing.
