D, S, Generate Primitives From Outline. There should be a layer you're using as the board outline (usually Keep-Out) for all the board shape to go on. Mind that other objects (like that keep-out rectangle over your spark gap) don't add confusing or conflicting information.
Also, those slots look awfully thin. Check with your board house that they can actually manufacture them for you, or consider widening them to 1mm or larger (which is a common tool size for routing).
