Author Topic: Component Links Dont open in External Browser  (Read 4052 times)
Offline mengfeiTopic starter
  • Country: ph
« on: September 25, 2024, 03:31:52 am »
Component Links Don't open in External Browser or even locally, another tab just opens & then the tab has a %2A naming
I just added Manufacturer links to our components so when SCH part > right click > References > URL of Vendor > %2A
open external browser has been checked, tried key combi still nothing
has anyone faced similar problem & how to fix this? is there a setting needed for the external browser to see Altium Links?
thanks
Offline Bryn
    • mindsConnected
Re: Component Links Dont open in External Browser
« Reply #1 on: September 25, 2024, 07:24:30 am »
First and foremost, ensure that the option to open links in an external browser are enabled. You can find this option in the System Preferences menu. You might want to check that the default browser is set correctly as well.
Alternatively, or if any of these don't work for you, drag-and-drop of links to your browser would work and sometimes helps with the bypassing of issues relating to direct link opening.
https://mindsconnected.tech
Small tech forum...
  • Country: ph
« Reply #2 on: September 26, 2024, 03:03:44 am »
open external browser has been checked - done it a few times on & off still nada
dragging doesn't work too :-//
Offline thm_w
  • Non-expert
« Reply #3 on: September 26, 2024, 08:08:44 pm »
Works OK here, v24.9.1.
What version and did you try other versions?
  • Country: ph
« Reply #4 on: October 08, 2024, 01:40:07 am »
AD21
what is your settings & how was the links added?
we usually have all our parts in Z2DATA
thanks
Offline thm_w
  • Non-expert
« Reply #5 on: October 08, 2024, 08:41:58 pm »
Setting is as shown above. Link can be added manually for testing:
  • Country: ph
« Reply #6 on: October 10, 2024, 06:05:54 am »
OK, got it to work, we upgraded to AD24  ;D
Offline Teun
« Reply #7 on: November 21, 2024, 08:19:18 am »
I have the same issue. AD 20.2.6 Anyone found a solution for that? I'm not really in the position to upgrade to AD24 :'(
