Author Topic: Creating component with pin/subpart swap (resistor network)  (Read 495 times)
Offline martin_ngaTopic starter
« on: April 09, 2026, 12:35:07 pm »
i've recently changed layout design to Altium, so might be a trivial / "didn't know what to search for" problem. In the old software, this was a trivial problem.
I want to create a schematic library symbol for a resistor network containing four equal resistors.
The network has the following two swap options:
- pin swap a/b
- subpart swap a/b/c/d
I've created schematic and pcb symbol, but I can't find a way to pre-define the swap options for the lib part. Schematic has the option (parts action -> configure pin swapping), but I want to have this pre-defined in the lib.
Any idea how to do this?
Thanks for your help!
Regards,
Martin
Offline Pseudobyte
  • Embedded Systems Engineer / PCB Designer
Re: Creating component with pin/subpart swap (resistor network)
« Reply #1 on: April 13, 2026, 11:57:52 am »
In the schematic symbol editor part/pin swapping is configured under: Tools > Configure Pin Swapping
There should only be one component in the list so click on "Configure Component..."
“They Don’t Think It Be Like It Is, But It Do”
The following users thanked this post: martin_nga
« Reply #2 on: April 16, 2026, 11:20:54 am »
Thanks, that's what i was searching.
