Author Topic: Flex PCB Overlapping Branches – Component Placement in Overlap Region (Altium, 2  (Read 916 times)
Offline Prasad_2001Topic starter
  • Country: in
Description:
I am designing a fully flexible PCB in Altium where the main flex splits into two branches.
One branch (Yellow) bends 90° upwards
Another branch (Green) bends 90° downwards
Due to mechanical constraints, both branches overlap in a specific region (highlighted in red)
In this overlapping area:
Physically, both flex layers will occupy the same X-Y space, but at different Z heights after bending
Electrically and layout-wise, this region is currently the same PCB area
Refer image for details
My questions:
Is it possible to place components separately on both overlapping regions (i.e., one on top branch, one on bottom branch)?
Can this be achieved using stackup modification, layer definition, or rigid-flex techniques?
How can I differentiate these overlapping areas in Altium, since they belong to the same PCB layout?
What is the recommended industry approach for such overlapping flex geometries?
Offline Psi
As far as i'm aware you just cannot ever do that, or make it.
It has to be something you can express as a flat surface for manufacturing
There are some options to end up with something like that though...
- Have two separate flex pcbs with pads that get hotbar'ed together into the overlapping shape.
- Have it fold up into that overlapping position from a non-overlapping flat layout.
« Last Edit: April 29, 2026, 01:49:46 pm by Psi »
The following users thanked this post: ANTALIFE, Prasad_2001
Online Someone
    • send complaints here
Two options:
work extremely closely with your specific board house to deliver what they can work with and achieve.
or...
Don't!
Overlapping rigid flex within a planar panel sounds insane, I'd guess most board houses would reject the idea immediately.
Online Someone
I can imagine a few ways to do it, but the question is which PCB fab (and then assembler) would want to take the risks on a custom process ?
Offline Psi
And also, who would want to pay the $$$ costs needed vs doing it a different way without overlap when flat.
Offline Psi
i think they could hotbar it together as part of the pcb fabrication process, but if you wanted to do pick-n-place on both the overlapping segment i think they would through their hands up in horror.
They would need a custom jig for solder stencil and pnp that holds one overlapping area out of the way and put it through both twice.
« Last Edit: April 29, 2026, 02:03:48 pm by Psi »
Offline squadchannel
  • Country: jp
  • deepl translate user
I don’t know where the bending edges are.
However, I can say this: PCBs are not designed in a bent state.
They are designed as a completely flat. bending design is the job of other CAD software.
All PCB CAD software and PCB fabs create data based on the assumption that the PCB is completely flat.
  • Country: in
Thank you, everyone for the detailed inputs.
Overlapping geometries don't seems practically feasible within a single PCB—especially from fabrication and assembly perspectives. This may change in future.
The suggestions around using separate flex sections or redesigning into a non-overlapping flat layout make sense, and I’ll evaluate those approaches further.
Appreciate the clarity and insights.
