Author Topic: Pad Definition Troubleshooting in 4-Layer Stack Up  (Read 1021 times)
Offline MuriTheMythTopic starter
« on: June 11, 2024, 10:03:45 am »
Hi folks,
I hope you are well. I'm beginner in AD and this is the first 4 Layer board I'm doing.
I've defined square pad for the 1st pin of the header footprint in the footprint library. Though, only the top and bottom layer correctly followed the defined shape (see screenshots). I'm wondering what happened here.
Thank you very much to anyone who helped.
Sincerely,
Muri
Online Someone
    • send complaints here
Re: Pad Definition Troubleshooting in 4-Layer Stack Up
« Reply #1 on: June 11, 2024, 10:18:20 am »
Layer type, planes don't use pads.
« Reply #2 on: June 11, 2024, 10:27:26 am »
Problem solved! Thank you so much!
