Hi Tim,
I could not enable the layers in the library's layer stack manager. Now it works.
But (a much less of an issue) when I "expand"/scale the board thickness the planes copper remains "thin" but the top and bottom copper layers show quite thick. That is despite both planes and layers having the same thickness in the stack manager (as you can see from the screenshot). Do you know why that is and how to change it?
Also do you know if there is a way to expand/scale the layers evenly like in the old versions where regardless of each layer's material thickness defined in the stack, when scaling the PCB thickness they all move apart by the same amount (instead of proportional to their thickness)?
Thank you
