Author Topic: Preparing BOMs for multi-design panels  (Read 459 times)
Offline vixoTopic starter
« on: January 02, 2024, 09:06:55 am »
I made a panel containing 3 different designs, but I realised that I need a BOM for the whole panel because the part designators are re-used (for example R1 appears in all three designs). How should I do this? Making a multiboard project seems unnecessarily time consuming.
Online tszaboo
Re: Preparing BOMs for multi-design panels
« Reply #1 on: January 02, 2024, 09:16:16 am »
This is usually not done. Unless the project is very simple, it is going to get panelized per design. So if changes are made in one design you are not required to make changes to everything.
The following users thanked this post: vixo
