Author Topic: Scripted placement of Rooms?  (Read 3671 times)
Offline mrpacketheadTopic starter
  • D Size Cell
« on: July 15, 2015, 09:11:38 pm »
Hello to probably the best support of Altium on the planet.
I'm mid designing a project where I have hundreds of the same circuit segment to place on some complex shaped pcbs.  The pcb shapes where design in auto-cad and the component positioing is extracted out of that, and i get X,Y and rotation data in a text file.    I've been able to to extract that position data and move components around the board and get them in the correct place.   In the instance below, i read in a file that has the designators of a bunch of components, and then move them to the x,y specified point.     A big time saving..
I'd like to be able to do the same for an entire room of components though.. Does anyone know if you can move rooms in the same manner. I'm sure you can, i'm just not sure what its called.
Const ForReading = 1
' on mac generated .csv files run
' tr '\15' '\n' < coords.csv
' to fix end of line delimiters
Dim Board
Dim xCoord
Dim yCoord
Dim Angle
Dim Designator
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFile = objFSO.OpenTextFile("W:\nfatonion_altium\coords.csv", ForReading)
' Load current board
    If PCBServer Is Nothing Then
        ShowMessage("Not a PCB or footprint editor activated.")
    End If
    Set Board = PCBServer.GetCurrentPCBBoard
    If Board Is Nothing Then
        ShowMessage("Not a PCB or footprint loaded.")
        'End
    End If
    Call PCBServer.PreProcess
    Do Until objFile.AtEndOfStream
        strLine = objFile.ReadLine
        strLine = replace(strLine,"\15", ",")
        arrFields = Split(strLine, ",")
        Designator = arrFields(0)
        Dim Comp
        Set Comp = Board.GetPcbComponentByRefDes(Designator)
        If Comp Is Nothing Then
        ShowMessage("No Designator :"+designator)
        Call PCBServer.PostProcess
        End If
        Call PCBServer.SendMessageToRobots(Comp.I_ObjectAddress, c_Broadcast, PCBM_BeginModify , c_NoEventData)
        xCoord = arrFields(n+1)
        yCoord = arrFields(n+2)
        Angle = arrFields(n+3)
        Comp.X = Board.XOrigin + MMsToRealCoord(xCoord)
        Comp.Y = Board.YOrigin + MMsToRealCoord(yCoord)
        Comp.Rotation = Strtofloat(Angle)
        Call PCBServer.SendMessageToRobots(Comp.I_ObjectAddress, c_Broadcast, PCBM_EndModify , c_NoEventData)
Loop
Online free_electron
    • SiliconValleyGarage
Re: Scripted placement of Rooms?
« Reply #1 on: July 15, 2015, 10:03:57 pm »
you do know that you can load a pick and place file right ?
tools - component placement- place from file ...
  • D Size Cell
« Reply #2 on: July 16, 2015, 03:20:57 am »
No ,  thats a new one on me.   In my case, not sure if it would have helped,  i would have had to arrange my data into a suitable file, for it to have been read by altium,  either way, i'd have had to write some code/script to convert from one side to the other.
The big advantage of being able to move a room is that I can route one room out, then paste the routing format to the other ones..  Since i need to repeat this several hundred times, i'd love to be able to script the move.
« Reply #3 on: July 16, 2015, 03:48:32 am »
room copy only works if the schematic is designed as multichannel
  • D Size Cell
« Reply #4 on: July 16, 2015, 04:40:30 am »
Which it is. Thats not the problematic bit.      The problematic bit is moving named rooms to specific locations.
