EEVblog® Electronics Community Forum
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
PCB/EDA/CAD
Altium Designer
Solid regions in PCB components
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Solid regions in PCB components (Read 6848 times)
joelby
Frequent Contributor
on:
September 22, 2011, 08:31:29 am »
Hi all,
Does anyone have any advice on how to go about creating PCB components with polygon regions? I've designed a library component for
http://www.minicircuits.com/pdfs/SXBP-157+.pdf
and am following the "Suggested PCB Layout". I've made the ground pads (2-7) all the same pad (2), which is what Altium suggests. However I've defined the rest of the ground plane using a solid region on the top layer and because this doesn't have a net, it's causing short circuit DRC errors.
I can't set a net for the region because "No Net" is the only option provided.
Thanks!
Joel
Logged
JuKu
Country:
Re: Solid regions in PCB components
Reply #1 on:
September 22, 2011, 01:37:14 pm »
After placing the component, do "update free primitives from component pads".
Logged
http://www.liteplacer.com
- The Low Cost DIY Pick and Place Machine
joelby
Reply #2 on:
September 22, 2011, 01:51:05 pm »
Sir, you are a genius! Thank you very much.
Logged
JuKu
Country:
Reply #3 on:
September 23, 2011, 06:19:01 am »
Nah, no genius (but thank you anyway:-) ), just an experienced Altium/Protel user (since 1993(!)).
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
PCB/EDA/CAD
Altium Designer
Thanking...
EEVblog® Main Site
EEVblog® on Youtube
EEVblog® on Twitter
EEVblog® on Facebook
EEVblog® on Odysee
