Author Topic: Splitting a plane layer howto videos?  (Read 2870 times)
Offline analognoiseTopic starter
« on: July 10, 2013, 12:10:33 pm »
Hi all,
I'm using AD to create an FPGA board, and I need to either draw a polygon pour and use a signal layer or use a power plane with a split. I think I've managed to get the polygon pours correct, but I haven't managed to stumble into getting the plane layers to split.
Sorry if this is a very amateur question, but I've had a go of it for a while and can't make it move, if you will.
Thanks!
Online free_electron
    • SiliconValleyGarage
Re: Splitting a plane layer howto videos?
« Reply #1 on: July 10, 2013, 02:14:32 pm »
Go to the plane, simply draw a line where tou want to split (place track) and altium will split it. Its that easy.
« Reply #2 on: July 11, 2013, 05:50:11 am »
Shoot, I was selecting "Interactively Route Connections" rather than drawing a regular line.
Works like a charm now. Thank you very, very much! ;D
