Author Topic: #562 – Electroboom!  (Read 109614 times)
Offline Sredni
  • Country: aq
Re: #562 – Electroboom!
« Reply #800 on: January 04, 2022, 06:47:36 pm »
I don't think I have to repeat what I already wrote in the last thirty or so pages. Re-read them if you want.
You touted this 'two capacitor' example as the (yet another) definitive circuit that would jave brought 'team Lewin' to the ground.
It turned out not to be at all different from the original ring with two resistors.
In steady state resistances are exchanged with reactances. The induced field drives charges on the plates of the capacitors and instead of a conduction current we end up with a displacement current.
The setup is the same as that I used for the ring with the two resistors: a ring with two resistors around a toroidal core. There are no surprises. Everything is as it should be: a drop of 308 mV on the 4.7uF cap, negligible - basically zero - drops in the copper section, and a drop of 66 mV in the 22 uF cap.
This time I didn't attach the scope's probes, but I would have seen the same 180 degrees phase inversion.
If you want to waste time, you can compute the reactances, and the current.
I am asking you again: why did you insist this example was something special? It was a dud.
« Last Edit: January 04, 2022, 06:50:07 pm by Sredni »
Offline jesuscf
« Reply #801 on: January 04, 2022, 07:39:09 pm »
Will a ring made exclusively out of capacitors show an induced emf?  No wires, only capacitors in series replacing the ring, as well as the two original resistors on each side.  What would be the voltage VAD in this case?  Do you agree that now that there are not 'Lewin zero volt' short circuits anywhere?
Homer: Yeah, but faster!
Offline Sredni
  • Country: aq
« Reply #802 on: January 04, 2022, 08:09:57 pm »
And here we go again.
After the nth "killer question" is answered, not a comment.
And then "killer question" n+1 takes its place.
Answer that and the cycle repeats.
What if we made a ring of alternating capacitors and thermistors?
And a ring with thermocouples orbiting a neutron star?
What about a ring made of anti-matter?
And what if we changed the gravitational constant of the universe?
You are just wasting people's time.
The following users thanked this post: bsfeechannel, HuronKing
Offline jesuscf
« Reply #803 on: January 04, 2022, 08:45:32 pm »
Why so belligerent?  Are your servants on holidays?
Let me answer my question for you:  yes.  A ring made out of capacitors behaves as a ring made of wires or a ring made out of resistors: it picks up an induced emf.    Also yes, I did the experiment;  I connected 100 x 1uF capacitors in series to make a ring with the two resistors, 100 ohms and 900 ohms, and KVL works!  Why is this important?  Because it takes away Lewin's argument that the voltage across a arbitrary segment of wire under a varying magnetic field "shows zero volts because its zero resistance".  What if there are no wires?  What is the voltage between nodes A and D, VAD, then?  When Lewin argues that the voltage between the terminals of the opposing resistors in the ring is zero or that the induced voltage in the voltmeter probes is also zero, he is incorrect, and that is the source of this controversy.  The guy messed up and he won't admit it.  He even went so far as of trying to change the definition of KVL.  Too bad for Lewin that Maxwell himself wrote the definition of KVL in his 1873 book, which contradicts what he says.
If you think I am wasting your time, just don't read my posts or reply to them.  It is that simple.
« Reply #804 on: January 04, 2022, 10:12:24 pm »
What you omitted from §297 is the following:
Let the components of the current at any point be u, v, w.
By Ohm's Law the current is proportional to the electromotive intensity. Hence X, Y and Z must be linear functions of u, v, w. We may therefore assume as the equations of Resistance,
X = R1u + Q3v + P2w,
Y = P3u + R2v + Q1w,
Z = Q2u + P1v + R3w.
So, the resultant EMF inside a wire no matter its multiple origins must be its current multiplied by its resistance. So much for modelling a wire as a resistance in series with a battery. This agrees perfectly with what is being said all the time: the wires and resistors in Lewin's circuit only have a voltage that is their respective resistance times the current intensity and nothing else.
So, nice try pale face. Invoking the spirit of dead Maxwell won't help you. He was no fool.
But this sums up perfectly what KVLism is: an empty rethoric full of omissions, misinformation, disinformation and sheer stupidity.
As for Lewin causing "controversy". That serves you right. Next time don't chose ignorance over knowledge.
Offline jesuscf
« Reply #805 on: January 04, 2022, 11:30:17 pm »
Do you mean a wire in general, or a wire with an induced emf from a varying magnetic field?  Just asking, because you seem pretty confused with what you are reading.
Offline ogden
  • Country: lv
« Reply #806 on: January 05, 2022, 04:18:00 am »
Also you did not answer my 2nd question: how one can practically demonstrate path-dependency using transformer with let's say, 100 turns of secondary.
When you measure from the outside you can look at the measure in two ways:
the voltmeter shows the actual voltage in the gap between taps
the voltmeter shows the voltage along the portion of filament between the taps (which is the ohmic drop that is nearly zero volts) plus (or minus depedending on orientation) the linked emf (emf of one turn times integer number of turns linked).
Sorry, I do not see how this demonstrates path-dependency. Let's say - I measure 10VAC on 100-turn secondary of my transformer. Please tell how to set-up 2nd AC voltmeter that would demonstrate "path-dependency", measure 0VAC while connected to same terminals as 1st voltmeter measuring 10VAC? Do you agree that 100 turns of 2nd voltmeter test leads on transformer needed?
« Last Edit: January 05, 2022, 04:32:19 am by ogden »
Online Siwastaja
« Reply #807 on: January 06, 2022, 10:15:54 am »
This has been one heck of a ride.
Really the first thing I need to get off my chest is, I really appreciate the work by bsfeechannel and Sredni, and later thinkfat. Thank you for not giving up, and I also need to apologize. I don't remember what I exactly posted on the previous round (is it already two years or what?) but it was about bsfeechannel's writing style and completely uncalled for. Seeing how much pure stupidity you have to deal with, I admire the coolheadness you can still maintain.
Thank you for revisiting this again, because the fact that time has passed helps to see it in new light. It's also amusing to see how many have "converted". For the rest, quality is indeed going down.
Additionally to thinkfat doing full 180, my real eye openers were actually helpful comments by jesuscf and Jesse.
These guys repeatedly called all the math used gibberish, confusing, etc. etc., and it really hit home because I agree with them. Math as shown by Sredni is pretty much gibberish to me, as well. But there is one big difference; while hate admitting being wrong as well, I hate intellectual dishonesty even more. I simply can't go there.
Which gets us into the matter of credentials as discussed repeatedly. Personally, still in high school I really shone in math. Those integrals were a breeze. Coming to university however, the first few courses were still with full scores, but then my scores started dropping. It seems, while integrals as taught in high school were easy, now when multiple integral symbols with those small extra symbols like circles started to appear, number of different alphabets and writing styles to signify different entities blew through the roof, it become harder. I was able to pass exams still but had fundamental issues digesting it.
It didn't help that my curriculum was kind of special mix, originally designed to mass-produce design engineers for still growing Nokia (which later colossally failed), but I'm not sure if that mix worked that well. Only one course in very fundamental electromagnetism (dealing with these subjects) so while we had all the related math, it was disconnected. I never learned the Maxwell equations well. Then we mostly had signal processing, some computer science, some electronics, etc.
Finally, I failed the exam in vector analysis. This was the first time me literally failing math. In the end, I admitted the fact that I'm just not a math wizard, and I don't need to be. Different people have different skills. I know enough math to know what I need to know, so that I can ask for help from the right people if the task requires it. This also makes me appreciate those who can deal with complex math. Their skills and understanding in electromagnetics have enabled all the nice modern things we have, so that more simple-minded engineers like myself can just buy a lumped module which deals with all the voodoo internally.
And now we get back to the eye opening moments. The bullshit generated by J & J in this thread could work for some readers, say, a carpenter or plumber with no university math background.
But for me, it doesn't work. Sredni's math might look gibberish-y enough for me so that I understand how J & J feel about it, but on the other hand, I still remember enough of the Vector Analysis and Electromagnetic fields and waves that I can see chances are very high Sredni knows exactly what he's talking about. Even if that is unsure, it's certainly sure that J & J have absolutely no idea about the math involved whatsoever, even if they are capable of copy-pasting some terms and putting them together to form sentences cargo cult way - think about "lumpable paths" & co.
So, finaly I asked myself what is the real dispute here, behind the endless loop of fog screens.
It is the question:
Is Lewin's original circuit lumpable?
Because non-lumpability is hard to prove (like nonexistence of God), requiring mathmematical concepts not everybody seemingly understand or agree about, the burden of proof has to be turned around: prove that KVL works.
And I think the only sustainable, intellectual honest way of debating about this would be this very process:
* Show an equivalent circuit -> show that the real circuit behaves like that equivalent circuit
* Now disputing this is easy; just show how the given equivalent circuit does not work. Single datapoint suffices.
* Now the author is required to come up with a new equivalent circuit, until it works - or doesn't.
And this is what I have not seen. I'm serious. I have not seen a circuit diagram, showing an equivalent circuit, and Kirchoff based calculations that get the result matching with the experiment.
Instead, I have seen videos of special 3D arrangements made for the task.
So I think I know where the issue lies.
It's the fact that a 2D circuit drawing with nodes, KVL applied, is not sufficient alone. To get it working, extra "hidden" information is added; not necessarily even hidden, not everyone is dishonest with this, but nevertheless it seems the exact 3D construction is the crucial part. This cannot be conveyed with simple circuit mesh diagram, otherwise it would have been done already.
So the model is not a equivalent circuit that can be drawn as a diagram; no, the model is a photograph or usually even a video showing a careful 3D construction. Only within this model, the KVL seems to hold.
As soon as you change this model - while the 2D circuit diagram keeps the same! - the model breaks up. This is then called "bad probing".
But Kirchoff laws and simple 2D circuit diagrams with lumped components were never supposed to cover such complex cases. Sure, you can force this approach, by adding new layers of information (like, add a photograph describing the exact layout required, to the point of showing correct ways of probing), but then the question is, is this way of modeling beneficial? Or maybe going to the lower physical level with wider generalizations, using known, true and tested principles - for example, Maxwell equations on paper, or modern EM field solvers/simulators - would make more sense?
In any case, it's quite a mystery how this discussion actually started, and though I originally contributed this to Lewin's "flashy" way, I now think it's more because of how Mehdi represented it. After all, many have seen the Lewin's lecture, and it did mean nothing until Mehdi "set up the stage" so to speak, introducing the concept of "being wrong", which is actually quite ridiculous if you think about it deeper.
Lewin's lecture isn't that special; it's completely normal to see lecturers show examples "how not to do something". It's quite a stretch to think this shows that "the lecturer doesn't know how to do it". No shit Sherlock, that's the whole point. I could understand this from someone who has never attended university lectures, but it's surprising to see from Mehdi.
Really, the eye opener should be the fact that "correct probing" requires carefully thought out geometric constructions. This is not what I mean when I, as a practical engineer, talk about correct probing. For me, correct probing means avoiding extra loop caused by the scope's ground clip, instead using the small springy thing to connect to the terminals of the small output capacitor, for example, directly. But this is only possible if the thing to be measured is a small physical point (like a 0805 capacitor). In other words: a lumped circuit, or a close approximation of it! If you are measuring between wide area of circuit, under influence of external field, then obviously the presence of leads cannot be avoided in any way. They become parts of the circuit. The definition that "correct probing" is the one that happens to give consistent results per equivalent circuit + KVL is of course backwards. We should use capable enough models so they can model the real world, not the other way around (constraint the real world until it matches with the simple model), because latter limits out capability of building useful circuits. We can do better.
« Last Edit: January 06, 2022, 11:07:42 am by Siwastaja »
The following users thanked this post: thinkfat, HuronKing
Offline jesuscf
« Reply #808 on: January 06, 2022, 03:55:14 pm »
It is the question:
Summarizing a bit:
1) This extremely simple circuit is perfectly lumpable.  There is nothing to it really.
2) This circuit has been solved correctly in electromagnetics textbooks by experts in the field.
3) Both Jesse and I have done experiments that demonstrate that KVL and measurements results match perfectly.  Just need to be carefull when measuring.
4) Many people have debunked Lewin's claims, including Mehdi, RDS accademy, and Mabilde.  Neither Jesse nor I are the first ones.
If you don't know how to use KVL, it doesn't mean that KVL doesn't work!
« Last Edit: January 06, 2022, 04:20:43 pm by jesuscf »
Online Siwastaja
« Reply #809 on: January 06, 2022, 04:58:33 pm »
This is a pretty good conclusion, actually.
Any tool can be used to solve any arbitrarily generated problem, to prove anything, as evidenced by all those weird videos showing a specific way of doing a thing which has no practical application (and which is also not the same experiment as Lewin's, so why do it to prove anything about Lewin's experiment is beyond me :-//).
Look at it this way: Lewin has shown an experiment where clearly the measured outcome doesn't match with KVL. This is undisputed. You guys are spending great effort in building significantly different experiments (to the point they look something completely else even to a plumber's or carpenter's eye) that shows that in these experiments, KVL holds. Yet when suggested to add small modifications to the experiments, you won't do it.
What's the point? Like, world is literally full of circuits where KVL works, no one says it isn't a useful tool that works in most everyday circuits. It's the workhorse of basic calculations in the whole electronics industry. What's the deal? My current interpretation is, it's all because Mehdi "set up the stage" to make it like an attack against some good thing which is KVL. The rest just follows. This is ridiculous. Look, it's originally a university lecture. It's not aimed at practical engineers. The target audience are people who can deal with such stuff, analytically, using math, and don't take an offense on behalf of their favorite tool.
So practical engineers like myself continue using KVL every day. It is a really suitable tool for so many circuits we engineers design. Actually, I have never had to resort to either expensive EM simulation packages, or hand-calculating with Faraday's law. I'm pretty sure latter is very rarely done in modern days circuit design. For me, assuming lumped components, and radio stuff only inside radio modules which I keep within the suggested physical separation away from the rest of the circuit, using online transmission line impedance calculators and Spice simulations has been enough.
Again, I don't have to master everything, that's why we have teams of people.
But this all gives the false impression that the underlying physical laws are not important. No, there are and always will be difficult cases where deeper understanding, and better tools than Kirchoff laws are required. You or me might never encounter them. But Lewin's original experiment sure is one, that's undisputed - the result does not match the calculation. Now you can claim that the experiment is wrong ("wrong probing" is part of the experiment), and for some sake of "KVL justice" it needs to be modified using "good probing"; but sorry, that's only an opinion of yours. In my opinion, no experiment is wrong, if the aim is to gain understanding. Here, it helps gain understanding that the actual physical definition of voltage is pretty weird to us practical engineers!
It's actually quite similar to the "Arduino hobbyist fallacy" when Arduino was blog-credible over a decade ago. I was constantly lectured at that my skills of designing circuits are superfluous because you can always buy an Arduino shield which does that. Well, that is seemingly true to many, but someone has to design the products and circuits that do not exist at yet. Someone has to design those Arduino shields.
Similarly, someone has to design those RF modules, those 5G base stations, GPS satellites, and so on. These will always contain subsections where KVL does not work.
If you work there, you can't say "hey, I modified that circuit to look - and perform - physically different to be able to use KVL, because KVL is good if you do that". No, KVL has no such value. It has only value as a tool.
Then again, if my circuits end up being inside strong varying magnetic fields, I can just choose to call that "interference", and try to follow the rules-of-thumb of EMC design. Again, if the field is strong enough to matter even after that, I can call "foul play", clearly there is a radiating source that exceeds the EMC regulations. Again, Faraday avoided :phew:.
And a carpenter doesn't need to know shit about metallurgy, yet is still able to hammer in nails. But someone's got to do it.
« Last Edit: January 06, 2022, 05:09:30 pm by Siwastaja »
The following users thanked this post: HuronKing
Offline jesuscf
« Reply #810 on: January 06, 2022, 05:10:19 pm »
Except that the measured outcome of Lewin's experiment DOES match KVL calculations!  Just draw the correct equivalent circuit, solve, and presto: the KVL solution matches experimental measurements!!!  Maybe I am pointing out the obvious, but if you don't solve the correct circuit you'll get an incorrect answer.
Online Siwastaja
« Reply #811 on: January 06, 2022, 05:45:28 pm »
Maybe the issue is that you take this too seriously? Like, fit the KVL no matter what. When the actual goal was to learn beyond KVL. If you just look past the "dispute" which started after Mehdi's video, and look why the university course exists in the first place...
I mean, the whole idea of that university course is to teach underlying laws of electromagnetism. They need an example where the existing knowledge (how equivalent circuit is formed) is not a suitable tool for the job anyway, in order to teach the more general physical laws.
I'm sure you'll (or maybe not you, but someone) be able to make KVL seemingly work in organizing the equivalent circuit just right. Why wouldn't you - your schematic can, after all, contain infinite number of circuit elements, so you can make it perform any circuit function, including what Lewin's voltmeters showed. The question is, now your equivalent circuit encodes information about the external field (what if the field looks like Bart Simpson's face?), and about the placement of measurement probes, to get the correct result. I'm still no mathematician, but if this was the preferred way of calculation, it would be used. Instead, at some point, when the limits of equivalent circuits and Kirchoff laws are getting closer and closer, transition to more advanced (more fundamental) methods are fruitful, finally to save work.
But if you only have a hammer...
I think this is, in essence, what that MacDonald guy was saying in the famous excerpt quoted in this thread a few times.
Offline HuronKing
« Reply #812 on: January 06, 2022, 06:09:28 pm »
@Siwastaja
I am incredibly impressed with your post. You're absolutely correct that while these ideas are 'fundamental' they are not necessarily simple. I also had a similar experience to yours with vector calculus and such. I had a tough time in my 'pure' mathematics classes learning vector calculus. It actually didn't 'click' for me until I took Applied EM from an incredibly good instructor who was an expert in RF engineering and waveguide antennas. He showed me the way how these vectors and integrals can make physical sense in nature.
Hmm...
A consequence of Faraday’s law of induction is that Kirchhoff’s loop rule (which states that [integral]E · ds = 0 around a closed path) is no longer valid in situations where there is a changing magnetic field. Faraday has taken us beyond the comfortable realm of conservative electric fields. The voltage difference between two points now depends on the path between them. Problem 7.4 provides an instructive example of this fact.
Purcell & Morin, Electricity and Magnetism, 3rd Edition, Chapter 7.6
So induced voltage is path dependent.
And one, or all, of these debunkers has said that KVL holds 'in all cases.' That's wrong.
« Last Edit: January 06, 2022, 06:14:19 pm by HuronKing »
Offline jesuscf
« Reply #813 on: January 06, 2022, 06:35:53 pm »
Check example 6.6 from Electromagnetics by Notaros.  That is how Lewin's circuit should have been solved.  Pay attention to Figure 6.10b where the equivalent circuit to be solved is correctly presented.
EDIT: " [integral]E · ds = 0 around a closed path" is not the general definition of KVL.  KVL must include all EMFs, included magnetically induced EMFs.  Says who you may ask?  Maxwell himself!
« Last Edit: January 06, 2022, 06:41:33 pm by jesuscf »
Offline Sredni
  • Country: aq
« Reply #814 on: January 07, 2022, 12:15:54 pm »
Soooo...  the EMF is located on top of the resistors, it seems. Half just above R1, and half just above R2. How many centimeters, exactly? The text does not say. Can you locate with a bit more accuracy? No?
Or maybe...
Maybe that's the "equivalent circuit" that allows you to "solve the problem from the circuit theory point of view" and that is one of the introductory textbooks that do not explain clearly to their easily distracted audience what they intend for V. Oh, wait, but it does explain what V is! Page 269, eq. 6.18
Eq = - grad V
(Eq is what I call Ecoul) and V is... the electric scalar potential. Only half of the potentials required to describe the total electric field. And the text also says so explicitly on page 277, formula 6.43
E(t) = - dA/dt - grad V
"We see that both potentials are needed for E..."
(the same expression I used to express Etot = Eind + Ecoul, even if recently I decided to call the scalar electric potential phi, instead of V - exactly to avoid this kind of confusion you are having)
So...
where is exactly the EMF, again?
(Lewin problem is solved as an exercise on Purcell, Morin: Berkeley Physics vol 2, Electricity and Magnetism 3rd edition)
(Yes, I have checked with the kitchen. They do have deja-vus)
Offline jesuscf
« Reply #815 on: January 07, 2022, 03:37:57 pm »
Or maybe...
Eq = - grad V
So...
What confusion are you talking about?  Every single circuit I tried matches the KVL solution.  You seem to be the one that is very confused.  Here, once again: the induced EMF in Lewin's circuit and the circuit of example 6.6 from Electromagnetics by Notaros is distributed uniformly across the whole circuit, on every component and piece of wire connecting them.  The correct way of lumping the induced EMF in order to solve for the voltage VAD is shown by Notaros.   Lewin on the other hand, didn't represent the induced EMF in his equivalent circuit at all!  No wonder he thinks KVL doesn't work.
Offline ogden
  • Country: lv
« Reply #816 on: January 07, 2022, 03:48:45 pm »
Lewin's team, please come down to the Earth and answer this simple question - about how to demonstrate path-dependency on real transformer with 100-turn secondary using two AC voltmeters one showing nominal AC volts, another 0V. Many will be pleased to discover something they do not know yet. [disclaimer] I am usually not that persistent, but I feel like Killer Question (© Sredni) has been asked.
« Last Edit: January 07, 2022, 03:50:33 pm by ogden »
Offline Sredni
  • Country: aq
« Reply #817 on: January 07, 2022, 06:39:47 pm »
Yes, the current question is always the killer question.
Until it gets answered. They it becomes the forgotten question.
And killer question n+1 makes it appearance.
Online Siwastaja
« Reply #818 on: January 07, 2022, 06:52:09 pm »
It didn't occur to you that university stuff is not supposed to be down to Earth. It's not supposed to be dumbed down and simplified. This is about the theoretical basis, which has to be understood when designing RF layouts, or when designing EM field solver simulators. Someone have to do those, even if you only buy a transformer or pre-certified RF module and use them within the datasheet conditions.
And indeed, designing an actual RF communication circuit would be a perfect example where Kirchoff laws do not apply. This is obvious to anyone seeing an antenna, a wire that goes nowhere, yet radiates energy out. Still, I'm sure if you try enough, you'll be able to somehow make use of Kirchoff laws by modeling the transmitter and receiver pair as a schematic. After all, you can use infinite number of circuit elements. But is it the right way?
If I understood your question right, one of the many possible answers to your question would be, by piercing through the possible packaging and looping the probe wire 100 turns around the core. This is completely unfruitful. No one uses Maxwell equations in everyday engineering with everyday off-the-shelf transformer, the whole idea of that component is that it performs as a lumped circuit, a black box.
This was never anyone's intention. You have been only fighting against made-up strawman for years. Come on! Let the academics do the academic discussion their way; the track record is excellent. We "practical engineers" should learn something about it, even if we don't go fully there. Forget the ego for a while.
« Last Edit: January 07, 2022, 06:58:23 pm by Siwastaja »
Offline ogden
  • Country: lv
« Reply #819 on: January 07, 2022, 08:27:22 pm »
You both - please, please tell exact, easily repeatable steps of experiment KVL'ers shall do - to test path-dependency themselves. All you can come-up until now is just  :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah: :blah:
[edit] Sample (toroid) transformer picture attached. Assume it is 12 ACV transformer so KVL'ers can get it easily if interested.
« Last Edit: January 07, 2022, 09:21:37 pm by ogden »
Offline thinkfat
    • Matthias' Hackerstübchen
« Reply #820 on: January 07, 2022, 08:31:35 pm »
Thing is, if you had some basic understanding of the matter, you'd know that your question is irrelevant to the matter.
Offline ogden
  • Country: lv
« Reply #821 on: January 07, 2022, 08:41:06 pm »
Really? - Most pathetic excuse of no explanation ever seen. If you are not able to explain your "science" to your grandmother - you do not know it well enough.
Offline thinkfat
« Reply #822 on: January 07, 2022, 08:44:10 pm »
I'm not spoonfeeding you. The answers you're looking for are all in this thread. There's no value in repeating them over and over.
Offline ogden
  • Country: lv
« Reply #823 on: January 07, 2022, 08:50:02 pm »
I am asking SPECIFIC question about transformer with secondary winding of 100 turns which I am sure is not answered in this thread. Do not play stupid games please.
Online Siwastaja
« Reply #824 on: January 08, 2022, 09:54:32 am »
I already answered to that specific question - by looping the measurement wire through the core -, but it doesn't prevent it being re-asked repeatedly, just like before.
These people are indeed like broken records. Or maybe you want to hear the answer from Sredni or bsfeechannel? Maybe I'm not qualified?
In any case, the question is irrelevant, even if answered. A smoke screen. Playing games.
This is incredibly sad. I may have overestimated the EEVBlog forum community quality. On the other hand, the well known excellent posters on this forum avoid this topic like plague, and I well understand why.
Bulk of the appeal of this forum is completely built upon the contribution of ~10-20 excellent contributors (none of whom have posted regarding this matter, because, I guess, they are just facepalming).
Now I have realized how mediocre "practical engineers" can be totally manipulated into participating such needless and ridiculous war against science and education. Incredibly sad. (To be fair, I count myself in those "mediocre practical engineers". We can get a lot done. We may be more productive in building actual physical products that we forget that when scientists, physicists, mathematicians talk, we should at least listen and hone our basic scientific skills. Most of us are lacking there even if we managed to sit through university introductory lectures. That's a fact.)
So get off the high horse and read, read, and reread until you understand. I'm not the only one who did full 180 and needed to apologize. It's not easy.
The key difference in Lewin's excercise and ogden's transformer circuit is that the former circuit is completely placed within the varying field, making it impossible to route the probe wires outside of the field. The transformer? The field is contained within the core, and you can conveniently measure from the taps that are bought outside of the field.
« Last Edit: January 08, 2022, 10:09:13 am by Siwastaja »
