I have a 12v L.E.D light bar it has 60 leds(20 in series and 3 of those in parallel if im not mixing that up). The center 20 leds just barely light up, so I poked around with my multimeter like one does, every led works when tested, but when I measured everything while 12v was applied the driver circuitry for the center measured 55-60v but the other 2 drivers only went to 12v. I compared sections and everything measure the same till I get to 2 caps where I get the 55-60v, am I wrong in thinking its a bad inductor. ....... Its an old light bar that was on a truck it did have water work its way in. I did clean everything up with a nylon brush and alcohol, to my eye no leads or pads broke/rusted off. Thanks for any help/advice etc.
