I want to build gimbal, but i dont know which ESC-like controller should i use to spin my motors both CW and CCW directions. and i also want it to be compact, like 3 in 1 controller or sth.
Yeah, I believe the ESC for a gimbal is a bit different to a normal ESC used to spin the motor.
Since the ESC applies power with the motor pretty much stationary and with very fine control.
Sorry I cant help with an actual ESC recommendation. Have you tried searching for ESC and gimbal together?
Gimbal motors are run under an angle feedback regime, standard ESCs are not normally used with them. The angle error is used to control motor drive phase and level with a control loop tuned to the system involved. However standard ESCs should be able to spin them, but you won't get position control or good low-speed control that way I fear. RC car ESCs tend to have reverse options, RC plane ESCs tend not to...
