Author Topic: 30A OR-ing Circuit?  (Read 13614 times)
Offline PeteDTopic starter
30A OR-ing Circuit?
« on: June 26, 2015, 03:47:10 pm »
I'm looking for information on OR-ing circuits.
I have a 3D printer that works well for the most part, but it is underpowered when it comes to heating the bed.  I'm usually waiting about 45 minutes to an hour for the bed to heat up to 100C, and the wait is irritating me. Others with my type of printer recommend using a 24V 30A PSU and a 100A SSR to get the bed heat up time to less than 10 minutes.  Unfortunately, I'm on a budget and don't want to spend the $200+ that that solution would cost.
I have a couple of cheap Chinese 24V 15A switching power supplies, but linking power supplies is a little more complicated than putting batteries in parallel.  My google-fu has found some information on low voltage, low amp OR-ing circuits, but it has failed me in finding anything for higher currents and voltages.
Could someone who knows more about this subject than I (that wouldn't be hard, I've pretty much said it all in this post) point me towards more information on OR-ing design?  Also, are there any cheap solutions already out there?
Thanks,
Pete
Offline krish2487
Re: 30A OR-ing Circuit?
« Reply #1 on: June 26, 2015, 04:25:22 pm »
Yes.
Just use any standard diode bridge (medium to high A rating) and you are good to go
PSU1 ---|>---
                     \_________ TO LOAD
PSU2 ---|>---
As simple as that. For your particular application it is not critical about load sharing and such. Just make sure that you put a heatsink
on the bridge. Or if you can also go with a high A rating Schottky diode bridges like MBR20100 and short out the anodes too to get a 20A rated Schottky diode. Use several such to parallel your Power supplies
Like this.
                               ------------------- TO LOAD
« Last Edit: June 26, 2015, 04:27:29 pm by krish2487 »
If god made us in his image,
and we are this stupid
then....
Online macboy
« Reply #2 on: June 26, 2015, 04:29:29 pm »
You basically do just need to connect them in parallel.
To ensure current sharing between them, use ballast resistors. The simplest ballast resistor is simply the length of wire between the supply and the load. So, instead of connecting the two power supplies in parallel near the supplies then using a single length of wire to the load, use one length of wire to the load from each supply, making the parallel connection only at the load. The voltage drop across each length of wire helps ensure current sharing. The other important thing is to adjust the two supplies' output voltage to match as close as possible.
If you want true "OR"-ing of the outputs, you put a series diode on each output. Then you could technically use only one without having the disabled supply see the voltage from the enabled supply. You need really beefy diodes here. I have salvaged several suitable diodes from dead computer power supplies. They are in TO-247 (TO-3P) packages like transistors, but are actually high current Schokttky diodes. One that comes to mind is MBR3060CT MUR3060PT, a 30 A, 60 V (reverse) diode.
« Last Edit: June 28, 2015, 12:55:37 pm by macboy »
« Reply #3 on: June 26, 2015, 05:06:59 pm »
Thanks, Krish, Macboy!
It's good to know I was over complicating this.  About how much heat should I expect from a couple of parallel MBR20100 diodes in normal operation?  Would attaching them to the sheet steel legs of my printer's stand be enough to dissipate the heat, or should I get some heatsinks as well?
Offline PSR B1257
« Reply #4 on: June 26, 2015, 05:21:05 pm »
Define normal  ;D
At 15A you get a voltage drop of about 900mV (depending of the tempreatur), therefore 13,5W power dissipation. And this is a lot if you have no heatsink. In fact the diode would go up in smoke pretty soon.
Hard to say. It would probably do the job.
You should try it first with the method macboy suggested. Additionally you should trim (almost every SMPS has a little trimmer near the output terminal) the output voltage of the supplies to match each other. Ideally you also measure the current of both supplies simultaneously while they are at full load, to make sure, they spread the load current evenly.
However a diode bridge (also heatsinked of course), like KBPC5010 for instance, worth also a try.
« Last Edit: June 26, 2015, 05:32:32 pm by PSR B1257 »
In theory, there is no difference between theory and practice. But, in practice, there is.
Offline krish2487
« Reply #5 on: June 26, 2015, 05:26:07 pm »
Actually diodes decouple the PSUs from interfering with each others control loop.
If there is even a slight mismatch in the output voltage setting or length of the wires then the power supplies will
constantly "fight" with each other.
The diodes, on the other hand, ensure that each power supplies senses and regulates its own output.
13.5 Watts is not really a lot of power to dissipate. It can be managed with a decent sized heatsink.
PS: Scratch my suggestion with the MBR20100. The MUR3060 is more likely a better diode to do the job.
« Last Edit: June 26, 2015, 05:29:40 pm by krish2487 »
then....
Offline PSR B1257
« Reply #6 on: June 26, 2015, 05:52:16 pm »
As I mentioned  8)
Offline tszaboo
« Reply #7 on: June 26, 2015, 06:42:09 pm »
Any reason not to connect them in series?
Offline PSR B1257
« Reply #8 on: June 26, 2015, 07:16:11 pm »
using a 24V 30A
That gives a nominal resistance of 0.8Ohm.
At 48V you would get a current of 60A and a power of 2880W.
These supplies are not designt to limit the output current, they just switch of, if there nominal current (times a faktor of 1.1 ... 1.5 or so) is exceeded.
In general connecting SMPS in series is not more or less critical than connecting them in parallel if they are not designed accordingly.
« Reply #9 on: June 26, 2015, 08:43:24 pm »
OK, I'll stop trying to be too cheap and geek for some heat sinks.
Just curious, why do you think the MUR3060 will perform better than the MBR20100?  Better Peak Voltage?  It's unlikely these diodes will see 100V, let alone 600V, isn't it?
Offline Ian.M
« Reply #10 on: June 26, 2015, 09:23:58 pm »
As power dissipation is a major issue here, you want to look for diodes with the lowest possible Vf at a rated current greater than the max PSU output current.   I would recommend at least a 20A If rating, preferably 25A, as if one PSU trips out, the other one's current is likely to surge very briefly over its normal max rating before it also trips.   The worst case scenario voltage wise is one PSU running and the other tripped with 24V across the tripped PSU's diode, and any diodes with a voltage rating greater than 35V should handle that OK.  Avoid diodes with a grossly excessive voltage rating as they usually have a higher Vf as well.
Due to the fact that the PSUs cant operate in a current limited mode, its essential to have ballast resistors as macboy described above.  The output wires for each supply should be as far as possible absolutely identical, especially the length and both the +ve and -ve wires should be separate all the way to the diodes and build platform for optimum current sharing.
Offline madires
  • A qualified hobbyist ;)
« Reply #11 on: June 26, 2015, 09:40:59 pm »
There are dedicated ORing controllers which drive MOSFETs, like the LTC4357 or LTC4359 for example.
Offline dom0
« Reply #12 on: June 26, 2015, 09:44:16 pm »
What moron had the idea to heat these things with low-voltage DC?  :palm:
To contribute something meaningful also: get a fat transformer in the right range and do full-wave control with a SSR (on the primary!). Should give you >98 % efficiency, especially with a toroidal (xformer switching relays required then).
« Last Edit: June 26, 2015, 09:51:05 pm by dom0 »
Offline krish2487
« Reply #13 on: June 27, 2015, 12:59:28 am »
Not the voltage. The current. The Die itself is rated for 75A for the MUR3060.  :)
Quote from: PeteD on Today at 06:43:24 AM
then....
Online edpalmer42
« Reply #14 on: June 27, 2015, 02:16:16 am »
Instead of buying diodes and a heatsink and making your own, check at your local automotive supply store.  They probably have a battery isolator which allows you to have two batteries that charge together but are discharged seperately.  It's typically used when you have auxiliary loads like an inverter.  You power the inverter off one battery and start the vehicle with the other one.  The auxiliary loads can't drain the starting battery.  Electrically, it's nothing more than two diodes and a heatsink!
Offline rx8pilot
« Reply #15 on: June 27, 2015, 04:15:36 am »
Build an 'ideal diode' with a controller and a MOSFET. Wont need a heatsink and can do it with about $15 or so - probably less than the value of the heat sink needed for a normal diode.
I have been using LM5050 but there are tons of options out there. Find a low Rds(on) mosfet and a few other parts. It
Offline PSR B1257
« Reply #16 on: June 27, 2015, 07:14:12 am »
What do you get, if you switch the MOSFET on? Basically a piece of wire. Meaning you are shorting out both supplies, which is the exact opposite of what we want here.
The topic in this case is chosen rather confusing. He actually wants an ADDing circuit since both supplies are intended to deliver power simultaneously  ;)
Offline madires
« Reply #17 on: June 27, 2015, 11:07:51 am »
Have you ever read any datasheets and application notes of ORing controllers? They got a reverse current protection, i.e. if current flows the wrong direction, the MOSFET is switched off. Most controllers use the R_DS_on as current sense resistor.
Offline rx8pilot
« Reply #18 on: June 27, 2015, 04:29:03 pm »
Sort of....you are not shorting the supplies - you are putting them in parallel. This will only happen if current is flowing out of each supply. If one supply dies or is a lower voltage the high side supply will not backfeed into it. The only purpose of the diodes (or ideal diodes) is to prevent reverse current that will damage the supply.
It does nothing to help balance the load, which is an additional effort if the load needs to be evenly split. First things first - don't allow one SMPS to feed into another and ideal diodes are designed for that with very little heat dissipation or voltage drop. The title is asking about an OR-ing circuit which is exactly what a diode (OR'ing controller) does. Perfectly matching the supplies is a longer conversation. If it were me, I would use two isolated heaters that each SMPS can handle on it's own.
Offline PSR B1257
« Reply #19 on: June 27, 2015, 06:17:16 pm »
Of course not shorted in terms of shorted from V+ to V- but shorted in terms of a quasi zero ohm connection from V+ to V+ and V- to V-
Offline madires
« Reply #20 on: June 27, 2015, 07:28:46 pm »
Sharing the load is quite simple ;) Assuming that both PSUs got different output voltages, the PSU with the higher voltage wins. But if the load is too large for one PSU the PSU's output voltage drops until it's not far off from the output voltage of the second PSU. The second PSU starts providing current. Get a dual-channel lab PSU, add two diodes and a shared load. Then set the output voltages to be 1V apart. Slowly decrease the higher voltage and watch the currents. Yes, it's simple like this.
Offline rx8pilot
« Reply #21 on: June 27, 2015, 07:35:08 pm »
I understand how the highest voltage wins. The problem is that each supply is only capable of carrying a partial load. Because of that, you cant have one supply win over the other because it will ve overloaded and possibly shutdown. When it does shutdown, the other supply will also be overloaded and fail.
Offline dom0
« Reply #22 on: June 27, 2015, 07:42:36 pm »
This can work with OVPd supplies, too, but only if the output resistance of the supplies is high enough to ensure balanced currents before OVP kicks in (or the supply fails). Now, with a good supply output resistance is very small and consists mostly of irreproducible contact resistances...
In redundant server supplies they do it with a current-sharing line, which acts as a control line for all supplies. Basically each supply puts a voltage proportional to it's load current via a resistor on that line and an error amp ensures that every supplies load current is about current-sharling-line / n.
« Last Edit: June 27, 2015, 07:44:40 pm by dom0 »
Offline LukeW
« Reply #23 on: June 28, 2015, 12:51:20 pm »
Do you really need 720 watts (30A at 24V) of power to get a 3D printer's heated platform up to an acceptable temperature quickly?
I seriously doubt it, unless it's one of those "print something the size of a house" things.
What kind of bed heater are you using exactly?
What voltage is the heating element designed to run on?
What is its resistance?
« Reply #24 on: June 29, 2015, 03:09:06 pm »
The heated bed is a 12" diameter plate with the heating element in 1/8 inch thick fiberglass.  On top of the heating plate there is a 1/8" thick aluminum disc, a 1/8" thick borosilicate glass disc, and a 1/32" thick disc of PEI.  The 100K thermistor is attached to the heating plate.
The Onyx heating plate was designed to run with 12V and 24V PSUs.  I am currently using a 12V 450W power supply.
I haven't measured the resistance of my heating plate, but it is advertised to have a 1.1 Ohm resistance at room temperature.  Some users have seen a higher RT resistance on their plates.
« Last Edit: June 29, 2015, 03:10:51 pm by PeteD »
