in the whole circuit? A mix of 72 Logic Gates, 1-8input NAND, and 10 inverters. I thought about a programming device, but by the time I add all the tansistors/mosfets needed to drive what the logic gates do, then I'm at the same or higher footprint size of the PCB Board. The Logic gates, most of them, are sinking and powering an LED so a transistor isn't needed.
I was just hoping to keep all my Logic Gates the same package size. But that XOR gate is the only one that doesn't come in the SOT-762 (DHQFN14). I wonder if I could just change them all from CH to the AHC series and be okay.?
