Hey all.
I am a lawyer first, guitarist second, and tinkerer third. I can read a schematic, I can use a Fluke to test for resistance, current, and voltage (both AC and DC), I have built tube amps from schematics. I am scared of the B+ supply in an old Ampeg SVT (for good reason).
But that being said, an EE I am not. I have been mostly self taught. Recently I learned about P-Channel jfets and diagnosed a guitar pedal with a FET switching system and then built a test rig to watch a JFET "open" and "close" as a switch when voltages were applied (super neat!)
Here is the issue....
Many of the guitar effects processors (called pedals) run on a 9V battery OR a 9v AC wall wart. Normally, there is a 5mm barrel (female) on the unit, and it is sold with a 9v (normally it is center negative) AC plug unit that terminates in a 5mm barrel connector and 2.1mm center pin. The female barrel is a switching connector and disengages the battery leads when a wall wart is connected.
Here is my question:
There are MANY MANY MANY things that use a 9v center neg adapter supplying 200-500mA. I grabbed three at the local goodwill. They all had labels (or embossed lettering on the unit) which said they were 9v DC output (120vAC 50-60Hz input) and generally supply .3A to 1A (although 200mA and 300mA seem the most common).
Here is the rub. Every one (albeit without load) showed 13v on my Fluke and the same on my scope (older tek).
On the scope (no load), the output of all three was giving me ripple free power, but I am unsure if these are built to supply 13vDC and will "drop" once connected to a load drawing 200-300ma current. OR, do most non guitar things not care if there is an extra 3-4 vDC shown to them??
Thanks
