Hello again after a while!
Now I own the device and here's an update about my findings so far. As a reminder: I wanted to convert an electrical shaver to USB charging.
The Power SupplyPhilips A00390; 4.3V, 70mA
I testest it and it is limited to around 95 mA output current. (I even shorted it and it supplied these 95mA "to itself".) When in use, the voltage breaks down to about 2.0-2.1V. The power supply has no clever charging shutdown, not even time based; you could leave it on for days it would "charge" further on at 95mA.
The ShaverPhilips QC3340,
Multigroom 3000; 4.3V, 0.5W
It has NiMH accumulator inside. I provided a voltage of 4.3V and it drew amps "out of limits" on my multimeter, so we can savely assume that there is no way a charging regulator inside of the device; the power supply is "in charge" of providing a pleasing current of 95mA for the accumulator. I assume the accu is built for standard charging at lower rates. While so, as far as my understanding of charging accus goes, it is not a big problem when the power supply has no charging shutdown, since it is not that incredibly unhealty when providing ongoing lower-rate currents. So Philips built this really down to a price; but hey, it's ok and it works (appears to do).
The Conclusion And The Ideas–A–
In order to get rid of the power supply and convert to USB-charging, it seems, that I just need to current limit at about 90mA. Is there an IC or a small module that you could recommended for that kind of job? I already stumbled upon
this kind of thing, the Infineon BCR 420. Are there alternatives to consider?
–B–
By measurement I obtained a value of 2.2-2.3V to provide to the accu in order to get a charging rate of about 80-90mA. I wonder if it will be ok, when I just set the right voltage and charge the accu with that simple method. I know I have to monitor the current rate over time to be absolutely sure that there is no mess going on at some point. Also temperature variation might be an issue.
–C–
I have a
LiPo charging module with the
TP4056 on it. I wondered, whether I could use such a thing to charge NiMH also. LiPo chargers do have a constant current charging phase before the constant voltage charging phase is triggered. And again, as far as my understanding of charging accus goes, this triggering will never happen with NiMH and it will charge ongoing at the preset constant current. This current (80-90mA) I can set by soldering a different resistor on the board, so the datasheet states. So maybe thats also a solution for me?
Thanks for bearing with me,
any suggestions and thoughts to this little hacking project are most welcome!
Darkwing
