Author Topic: Recommended relative humidity in electronic lab  (Read 2204 times)
Offline Hrvoje-CROTopic starter
« on: March 25, 2014, 03:28:55 pm »
Hi!
Well this one is relatively important thematic.
What is recommended relative humidity for electronic equipment/lab/el. components?
In my lab at this moment is about 50%, during summer is about 65%, even little bit more.
Thank you!
Offline electrolux
    • Photography
Re: Recommended relative humidity in electronic lab
« Reply #1 on: March 25, 2014, 03:33:53 pm »
Personally I think thats perfectly fine :-+.
The funniest thing about this signature is that by the time you realize it doesn't say anything its too late to stop reading it.
Offline free_electron
    • SiliconValleyGarage
« Reply #2 on: March 25, 2014, 03:44:35 pm »
the same humidity a on the calibration certificate. anything else is no-go
« Reply #3 on: March 25, 2014, 06:02:08 pm »
Maybe, but that can only be possible if using dehumidifier.
Offline HighVoltage
« Reply #4 on: March 25, 2014, 09:49:37 pm »
This depends largely on what the lab requirements are and what needs to be measured
I have one customer that needs highly accurate high voltage measurements and the equipment
is located in an air conditioned room.
This way, we can achieve a better than +/- 0.5 kV accuracy over a one year period of 40 kV Pk/Pk
An other client does not have any control over his room temperature or humidity.
Winter time down to 18°C and Summer time up to 35°C
Under these conditions, we can not even hold +/- 4 kV accuracy over a one year period of 40 kV Pk/Pk
So we need to calibrate the equipment once a month or when the temperature or humidity changes big time.
« Last Edit: March 25, 2014, 09:51:16 pm by HighVoltage »
