I am designing a circuit to control a 10W light bulb plugged in directly to 220V mains.
I am going to use logic gates for my control so I will have to isolate my control circuit (with 6VDC input) from the lamp (with 220VAC).
My professor ( a newbie professor, though i respect him ) said I can use 4N25 but after reviewing its datasheet, I highly doubt it will work.
Datasheets say the the maximum collector current is 100mA,
If P=IV then I=P/V then in my case I = 10W/220V , the current is 45mA (am i correct to assume this is OK?)
BUT the problem is with the voltage
Datasheets say that the collector-emitter Breakdown Voltage is 70V and 220V is too much
Any suggestions on how can i make this circuit work?
Or rather can you suggest other optoisolator that can withstand a direct 220VAC connection??
Thanks!!
