Author Topic: Storing videos from a camera directly in an SD  (Read 1026 times)
Offline bjancjTopic starter
« on: June 09, 2022, 01:24:20 pm »
Hello, I am working on a camera system that has to record a video and store it in some type of memory.
The main constraint here is space: it has to be very small, ideally less than 4x4x6cm, and lightweight. I found a camera that uses a USB 2.0, but I need a way to record its output.
Any ideas are greatly appreciated.
Thank you
Offline Jester
Re: Storing videos from a camera directly in an SD
« Reply #1 on: June 09, 2022, 02:27:11 pm »
I picked up one of those super cheap eBay cameras that records directly to a SD card. Seems to work okay. It has motion sensing and can be setup to record on power-up.
« Reply #2 on: June 09, 2022, 02:31:02 pm »
can you tell me the model so I can check it out myself?
« Reply #3 on: June 09, 2022, 05:34:49 pm »
Long story short, this thing has to fly, so it has to be very, very lightweight (max 100g) and it has to not consume much power. I will definitely look into dashcams and see what I can find.
Offline ledtester
« Reply #4 on: June 09, 2022, 08:24:57 pm »
What I think Jester is talking about is something like the "SQ11"  or what pops up when you search aliexpress for "minicamera":
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_20220609122143&SearchText=minicamera&spm=a2g0o.productlist.1000002.0
There's a bunch of different models so make a thorough search through the listings.
The cube cameras are very lightweight - the one I got weights 9 grams. Also note that mine didn't record any audio.
« Last Edit: June 09, 2022, 08:36:04 pm by ledtester »
The following users thanked this post: bjancj
