I developed a product I am very happy with and which I would like to take the next steps for.
The hardware as well as the code are working nicely.
I designed two pcb's within Kicad and had them manufactured and assembled (Version 4 so far)
In Fusion I designed a case consisting of three parts which fits nicely and holds the pcb's (1 fr4 1 MCPCB) in place and gives acces to the connections for audio, usb etc.
Now as this product is intended for a niche market and it is questionable if there is any money to be made I would liike to print shells, I can place the parts inside and pour a mould with silicone for later casting. I watched a lot of you tube tutorials on how to refine the prints for that but as I am dealing with plae surface I suppose that sanding by hand will endup with irregular depth of the surface (I might mode the part lying flat over sandpaper?) etc so I wanted to ask whether anyone has some infos on how to refine prints especially for enclosures and not for Star Wars helmets as the majority of the you tube videos show.
The second thing is precomplience tests. I am running 16 5W LED's each with their own driver on 20 kHz and switch those on and off in periods between 1 - 70 Hz. While I think my mainboarddesign / buck converter is verylikely to be solid I suspect the LED board to be a problem (not sure whether to switch to fr4 with holes for the COB's instead and sandwhich a mcpcb just for cooling purposes underneath). So I will have to do some testing before approaching a lab for a report.
As I am a dentist and everything is self taught I am looking for resources to read myself into regarding the use of a frequency analyzer etc. If you had some good links I would be very grateful.
Thanks for helping,
Jens
