"However, if the current is a time-varying function, I(t), this formula must be extended to reflect the fact that the current (and thus the instantaneous power) is varying over time. If the function is periodic (such as household AC power), it is still meaningful to discuss the average power dissipated over time, which is calculated by taking the average power dissipation:"
As the colector current is time variant (has a AC component) the aparent power is calculated using the RMS current. The Class C amplifiers has a greater aparent power than active power, because the colector current is not in phase and only the first harmonic that transfer active power to the output.
As he was calculating the efficiency witch is about the transferency of active power from the input to the outputs, he used the Mean current. This is my conclusion
