I am trying to find an analog multimeter that can measure AC current but I cannot find one.
There are however analog panel displays for AC current sold in ebay like the following:
http://www.ebay.com/itm/Class-2-5-Accuracy-Current-AC-200mA-Analog-Panel-Meter-/321063547608?pt=LH_DefaultDomain_0&hash=item4ac0e0f2d8Do you know in what way there are different from the DC current displays?
Will I be able to use an analog multimeter to measure AC current?
I have already bought one AC current panel display but if I can find an analog multimeter
that can measure AC current it would be great because I will use the housing for my
project and the panel would be perfect for measuring signal strength which in my case
is AC current.
Thank you.
AVO 8 MkV and mkVI have Ac current ranges from 10mA to 10A
So it does exist! Its very rare though.
Do you know if I will be able to use the panel from a DCA analogue multimeter to measure AC current?
The ICE supertester series (680R, 680G) also has AC measurements (I grew up using a 680R from my dad). One thing I liked was their huge display (check
this thread)
They can be obtained for cheap on ebay, especially since you are located in Europe.
That's a really nice multimeter!
The unigor is a nice meter, it not FET but transistor.
It works with a choppers and an AC aplifier.
It can measure 1 uA to 3 A ac currrent.
You can also look for an Philips PM2504.
It can measure 1 mA to 32 A AC.
