Author Topic: [solved] Analog voltage level conversion  (Read 1179 times)
Offline mnt22Topic starter
  • Country: jo
« on: December 25, 2020, 07:02:34 am »
Hi everyone
I'm trying to convert 0-10 VDC TO 1-5 VDC :bullshit: the tricky part is the conversion 0v to 1v by using electronic circuit not using any type of controller.
Thanks for the help
« Last Edit: December 26, 2020, 03:15:22 pm by mnt22 »
Offline Le_Bassiste
Re: Analog voltage level conversion
« Reply #1 on: December 25, 2020, 09:36:33 am »
using op-amps without any further circuit optimization:
(pardon my gimp-fu or lack thereof)
1138256-0
An assertion ending with a question mark is a brain fart.
The following users thanked this post: mnt22
Offline Zero999
  • 0999
« Reply #2 on: December 25, 2020, 10:55:12 am »
(Attachment Link)
This can be done passively, assuming the input/output impedance don't need to be excessively high/low.
Hi everyone
Thanks for the help
Assuming you have a stable 5V voltage source, all that's required is three resistors, but more may be required to get convenient values.
http://www.symres.com/files/scalebias.pdf
https://electronics.stackexchange.com/questions/22742/combined-adc-scaling-and-offset-with-variable-input-voltage-ranges
« Last Edit: December 25, 2020, 11:54:54 am by Zero999 »
  • Country: jo
« Reply #3 on: December 25, 2020, 09:04:02 pm »
The problem not solved because bias is not right with the desired signal it originally for prusser transducer replacement (0-10Vdc) replacing (1-5Vdc) the controller only can read (1-5Vdc)! If there are any ways to mapping this voltage actively or passively?  :-//  |O
Offline Zero999
  • 0999
« Reply #4 on: December 25, 2020, 11:00:53 pm »
It's not clear what you're trying to do.
Did you read the links I posted above?
If all you want to do is scale a 0V to 10V signal, to 1V to 5V and you have a stable 5V supply, then all you need are three resistors.
If you require a low output impedance, then add an op-amp buffer.
Here's a site which can calculate the resistor values. It also shows the op-amp buffer, which is only required if you need to drive a low impedance load.
http://earmark.net/gesr/opamp/case7.htm
http://earmark.net/gesr/opamp/gain_offset.htm
« Last Edit: December 25, 2020, 11:02:26 pm by Zero999 »
  • Country: jo
Re: [solved] Analog voltage level conversion
« Reply #5 on: December 26, 2020, 03:20:12 pm »
 :-DMM thanks Le_Bassiste and Zero999, Your kindness, generosity and thoughtfulness are greatly appreciated.  :-+
