Author Topic: Another What's this component question  (Read 1846 times)
Offline ketil bTopic starter
« on: June 30, 2015, 05:53:47 am »
Hi all
I'm currently trying to fix a bit of test gear that is too noisy, I thinks that I have track it down to the voltage ref or the filtering on it output.
The Vref is a LT1021-7 in a negative output configuration with a 100nF ceramic and the unknown cap in the pics, the marking are 10M8 16VF
Am I correct in thinking that this is a 10uF 16V Solid Tantalum?
thanks
Ketil
« Last Edit: June 30, 2015, 05:58:01 am by ketil b »
Offline PICmonster
  • Connecting the dots between hardware and software
    • InventaCircuit Technical Solutions
Re: Another What's this component question
« Reply #1 on: June 30, 2015, 01:49:38 pm »
That sounds reasonable, did you try and check the capacitor with an LCR meter?
« Reply #2 on: July 02, 2015, 03:59:17 am »
Hi
I finally got some batteries for my DE5000 and yes it is 10uF.
Just needed to double check because i haven't seen that formfactor befor.
thanks
ketil
