Author Topic: Any suggestions on taming the spikes from LM2596  (Read 9917 times)
Offline Rick LawTopic starter
« on: September 16, 2014, 04:39:32 am »
I can use some advice...
I've been using an LM2956 buck converter for a while and got comfortable enough with it that I forgot an issue it has: Spikes when under heavier load.  Now I need to use it for a slightly heavier load (2-3A), I have to face the regular spikes (100KHz ish, +- 100mV to +- 150mV).
A low pass filter R+C should in theory take care of it.  But putting 2 to 3A pass a 10ohm will drop the volt to nothing.  Putting a large cap (1000uF) across it (V+ to ground) alone (without a resistor) did delay the occurrence of the spikes, but when I am drawing 2-3A at about 7.5V, it is basically useless.
Any suggestions on taming the spikes?
Thanks
Rick
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Any suggestions on taming the spikes from LM2596
« Reply #1 on: September 16, 2014, 05:37:11 am »
What kind of spikes?  Input or output side?
Switching noise is easily handled with CLC filters, use low-ESR parts (like big ceramics) if possible.
Seven Transistor Labs, LLC
Offline mazurov
    • nerpa
« Reply #2 on: September 16, 2014, 06:07:21 am »
Broadband spikes (on the order of 100MHz, generated during switching "instants", sitting on the top of each output ripple extreme, see Linear Tech. AN70  ) will couple through capacitance of parts, including interwinding capacitance of inductors. For small output currents ferrite beads work well; for larger currents you may want to thread output wire through something like clip-on ferrite cut from USB cable.
An output ripple which increases rapidly while the load is increases gradually may indicate inductor saturation. If inductor is not saturated at max.load but you still don't like the ripple - use physically larger inductor with larger inductance.
« Last Edit: September 16, 2014, 06:10:37 am by mazurov »
With sufficient thrust, pigs fly just fine - RFC1925
Offline German_EE
« Reply #3 on: September 16, 2014, 11:26:41 am »
There are many things that you can do to eliminate the voltage spikes but it may mean a board redesign:
1) If possible use a ground plane design around the regulator area, if you cannot do this then adopt a 'star ground' approach.
2) Leads should be as short as possible for the following components:
Input capacitor connected to pin 1
Ground on pin 3
On/Off connected to pin 5
Schottky diode across pin 2 and ground
Output capacitor after inductor
3) Use low ESR capacitors on the input and output.
4) Keep the pin 4 feedback signal away from the inductor magnetic field.
5) Make sure that you are using the correct value of inductor for the voltage and current demanded.
Some experimentation may be required.
Warren Buffett
Offline mzzj
« Reply #4 on: September 16, 2014, 12:09:06 pm »
How is your layout look like and what other components you are using?
Or does this happen to be one of those ready made $2 ebay dc-dc converters?
« Reply #5 on: September 19, 2014, 09:43:12 pm »
Took me a few days to make the time to look into it in detail.
It is indeed a "cheap board", $10 cc/cv variety, $6-ish now, certainly not high quality stuff.  I am experimenting with digital control (which works well) to just play around - not anything serious to use but just to see what I think I know enough to make functional (is it so or not) and what I can learn from the exercise.
Finding the noise (which I knew but forgot), I connect up my other board (exact same board but unmodified) to get a base line to see if what I introduced made matters worst - yes slightly.  The unmodified one show that same noise at perhaps 10-20% lower noise peaks.  The trace below are made with an unmodified board.
The two attached photo are the noise (green trace on the posted pictures).  The first picture is the "fast" shot (scope too slow  to resolve the detail), the second photo is a zoom in by lowering the time/division.  The noise frequency looks like it is around 100-200KHz.
Looking at the noise closely,  I realize it may be the capacitor being drawn down, then for the rest of the switching cycle, it set at much lower level.  I added a 1000uF output cap.  It did a lot of good (say at 6V 100mA range), until the load increase to a point when the 1000uF got drawn down too.  By about 1A, the trace collapsed into a clipped triangle.  Just to validate, I upped the cap to a 4700uF, it delayed  the start of the collapse to a higher current.  Interestingly, when the power-draw is very high, the noise will go back down.  I suppose it is at a point where the charge is insignificant - which lead me to think perhaps I should lower the caps on the board.
I am not looking for a magic bullet.  I just like to hear some techniques so I can do more research into them, see how they work and see what I can learn.
Offline T3sl4co1l
« Reply #6 on: September 19, 2014, 11:31:49 pm »
That looks perfectly reasonable for supply ripple from single stage filtering.  If you need a low noise supply, add some CLC filtering, maybe some common mode (ferrite beads or chokes) too.
« Reply #7 on: September 20, 2014, 12:00:56 am »
Thanks, Tim - now I have something to look up and read: CLC filtering next step, see if I can learn  something...
Rick
Offline IC_Deerk
  • Country: cn
« Reply #8 on: June 09, 2026, 08:37:12 am »
Those 100-150mV spikes are typical for LM2596 at 150kHz. Several practical fixes:
1. Output filter: add CLC (pi) filter — 1-4.7µH inductor between two low-ESR ceramics on output
2. Ferrite bead: rated for your current on the output — good for high-frequency ringing
3. Snubber across inductor: 1nF + 200Ω RC snubber. Proven fix for LM2596 ringing
4. Layout: input capacitor must be as close as possible to Vin and GND pins
5. Post-LDO: if spikes are too high, follow LM2596 with AMS1117-3.3 — 60dB PSRR drops ripple from 100mV to under 100µV
Based in Shenzhen, China — happy to help if you're stuck sourcing hard-to-find parts.
Hobbies: electronics tinkering, Python scripting, data visualization.
The following users thanked this post: TUMEMBER
Offline xvr
  • Country: ie
    • LinkedIn
« Reply #9 on: June 10, 2026, 01:48:47 pm »
Resurrecting a topic that is almost 12 years old from the grave is not the best idea.
