I bought Arduino Nano V3 with Atmega processor and LCX 128x64. I need to connect LCX to Nano like on this schematic:
https://www.hackster.io/mircemk/simple-arduino-hulda-clark-zapper-with-timer-function-913ac2On Arduino Nano Microcontroller there are outputs allowing to connect cables without soldering but LCD has no such output. To connect the cables to LCX they have to be soldering.
First question is there perhaps a way to connect the cables to LCX without soldering? LCX has only holes where you can insert the cable but the cable will fall out without soldering.
Second question, if there is no way to connect the cables to LCX without soldering, what solder do I need to buy?
A bodge ive used is long pin male headers through the holes plugged into a female header on the other side of the board ,the plastic strip on the pins can be slid up and down to get things clamped tightly.then use male-female wires to connect the arduino to the display
Soldering isn't hard. Any solder for general electronics work with rosin core (NOT electricians soldering huge busbars etc) around 0.5mm to 1.0mm diameter will be fine. You'll only use a few cm of it for this, but of course it's handy to have some left over for later. One of the little plastic tubes with 15g or so of solder in a spiral inside will last a good while.
You can get a cheap simple electronics soldering iron for not much money almost anywhere, but the Pinecil is REALLY good, for not much money ($26 here):
https://pine64.com/product/pinecil-smart-mini-portable-soldering-iron/Or on Amazon for a little bit more (but likely free shipping):
https://www.amazon.com/PINECIL-Smart-Mini-Portable-Soldering/dp/B096X6SG13It's got a RISC-V processor inside and you can reprogram it if you want. But you don't have to :-)
indeed its not,however adding headers to a nano aint really an ideal starting point,might want to get a bit of 0.1" stripboard and some extra headers and get your technique dialed in first.
Yes, I will buy soldering.
