OK - here's the situation - Benq monitor..... volume is low.... I believe I know the source of the problem.... the actual input level from HDMI is low. As the monitor is being used on the end of a number of different devices, not all of which have separate volume control on board... there's nothing I can do at the source. - This has been checked as I have a second Benq monitor and swapped them for testing.
The monitor has a headphone output... but it's not putting out enough signal, coming through listenable but not by much, on a pair of standard impedance headphones (roughly 50 ohms I'd say) and even if I hook up to my old Logitec PC speakers, turning up to max volume on both those and the monitor, are just about comfortable listening, but still noticeably low, and no headroom for more power.
Hooking the headphone output to a decent amplifier works, but the volume has to be turned up high and there's hum present. Couldn't make out much on the oscilloscope.
There is a 5v USB power supply nearby, but I'm running out of mains sockets.
I did have a headphone amp unit, (Line5 headphone amplifier) but now that seems to not be working at all... with anything. So I might take that apart sometime down the line.
I'm presuming I want to boost it enough by a set amount so that the Logitec speakers can grab hold of something to work with. Possibly double, maybe tripple the signal.
