Hi all,im currently building one of these,im checking voltages as i go, here goes,dc input from rectifier is 28v,u1 pin 7-4 is 42v,pin 4 against rectifies ground is -15v,u2+pin 4+rec -ve =-5.1v pin 7+4=33v, u3 pin 4+rec -ve = -5.1v,pin 7+4 =33v,why do i get 42v on pin 7+4 on u1?,any ideas,i presume this is wrong?,this is without the ic's fitted,just the sockets,cheers in advance.
