Author Topic: Best boost converter topology for a 400V capacitor charger  (Read 1876 times)
Offline ZeroResistanceTopic starter
« on: April 12, 2018, 09:45:15 am »
I want to charge a 10uF cap, upto 400Vdc, my input voltage would be 12VDC what boost converter topology would be suitable for this ?
I have seen most people using the MAX1771 but currently I don't have that part in my kitty.
Edit: I am also looking for low EMI emissions, so I would preferably like a topology that is sine wave driven.
« Last Edit: April 12, 2018, 10:20:20 am by ZeroResistance »
Offline capt bullshot
Re: Best boost converter topology for a 400V capacitor charger
« Reply #1 on: April 12, 2018, 09:52:43 am »
Use a single transistor self oscillating converter aka Joule Thief
You'd need a suitable transformer anyway
https://electronics.stackexchange.com/questions/234656/reverse-engineering-camera-flash-charger
The following users thanked this post: ZeroResistance
« Reply #2 on: April 12, 2018, 10:22:16 am »
Many thanks bullshot, that's a novel idea, I'm wondering what kind of efficiencies does this kind of circuit exhibit and is it also notorious for noise / EMI generation?
« Reply #3 on: April 12, 2018, 10:27:49 am »
Boost controller w/FET + ATB322524, that's my usual choice for low power (1~3W) high voltage power supply.
Thanks for the info blueskull is this low on EMI?
Offline ogden
  • Country: lv
« Reply #4 on: April 12, 2018, 10:43:34 am »
I would use Xenon photo flash charger IC like TPS65552 or similar. Those ICs usually have "power good" indicator which is nice bonus :)
« Reply #5 on: April 12, 2018, 11:28:51 am »
This circuit is rather old, from ancient times where IC manufactureres didn't try to sell you a special IC for each special purpose (IC's weren't common at all then), and you'd have to come up with a simple and cost effective solution, more transistors would have been considered a waste of money. Anyway, it's so simple and effective, photo flashes were built this way over decades.
The efficiency is rather mediocre, there's some art in designing the transformer for maximum efficiency. Older designs were known for their typical whining "charging" sound, but that was because of the rather slowish transistors and diodes. Today, one can design this circuit with higher switching frequencies, so audible noise won't be a concern.
EMC and electrical noise isn't worse than any other boost converter.
« Reply #6 on: April 13, 2018, 05:38:10 am »
Are there any resonant topologies suitable for this application. I believe they would be efficient and low on noise?
Offline ogden
  • Country: lv
« Reply #7 on: April 13, 2018, 11:52:57 am »
There are quasiresonant flyback topology which indeed could be suitable for this application - in case you don't mind complexity of it.
