Hi all.
I'm new to this forum and I was wondering if someone could help me with this bode plot (image attached).
I'm just mucking around with filters on the bread board using op amps etc. I have a reasonably good understanding of the phase difference between the input to the filter versus the output at varying frequencies and what to expect, but I am fairly new to doing this kind of analysis and using the test equipment so it's quite possible that I may have set it up wrong. I can't understand why the phase trace on the scope jumps from -180° to +180° when the signal is around -6db. I can't imagine it doing it for real, and I thought it might be something to do with the way the scope interprets the information. If I set up the same thing in LT Spice, it doesn't do it.
Attached is a snippet of the filter (part of a bigger circuit for a cross over network) and the screen of the scope bode plot.
Thanks
