Author Topic: Bored with digital electronics, recommend me some challenging exercises.  (Read 2915 times)
Offline oslonTopic starter
  • Country: np
Except by doing physical projects, how can I make learning digital electronics fun?
I'm studying for some competitive examination after graduating with computer engineering. The problem is I am already on a job unrelated to electronics and I find it very boring to learn this stuff again as everything is just feeling repeated and rehashed. I am not learning anything new. It's like revising.
How do I make this a bit more interesting? I really don't have time for physical breadboard projects. Are there any time less things that I can do to make this learning interesting, it necessarily doesn't have to some project only. Any challenging exercises that can tease my brain can also help me.
Offline jpanhalt
Re: Bored with digital electronics, recommend me some challenging exercises.
« Reply #1 on: October 18, 2023, 07:08:48 pm »
If  you already know it all, then why keep repeating?  Just stop and move on to a job doing what you like.  In the alternative (i.e,. no jobs available) learn a new, marketable skill.
Offline Infraviolet
  • Country: aq
« Reply #2 on: October 18, 2023, 08:31:14 pm »
"Except by doing physical projects, how can I make learning digital electronics fun?"
Unfortunately I don't think you can. Projects are the whole point of it, only by applying it do you have fun, or even learn it properly.
If you can't get hold of the parts you need immediately you could try using a simulator to prototype some circuit concepts until you can get the parts and any test equipment you need. For digital electronics a simulator might be rather closer to practicality that in more analogue domains where real world imperections (your wires have inductance, your capacitors don't behave the same at all voltages...) are more important.
Offline Tation
  • Country: pt
« Reply #3 on: October 18, 2023, 09:34:29 pm »
HDLs
Offline alligatorblues
« Reply #4 on: October 19, 2023, 01:22:14 am »
Design and build a humidity gauge. You just need the sensor, 5VDC, ADC, and LCD display. Part of the ADC is an mcu to convert the voltage output from the sensor. You can power it with a cell phone backup brick..
Offline jpanhalt
« Reply #5 on: October 19, 2023, 08:45:58 am »
I find it difficult to reconcile your original question with your more recent post.
Source: https://www.eevblog.com/forum/beginners/what-is-a-digital-system-is-it-only-binary-or-decimal-octal-as-well/msg5121531/#msg5121531
I'm wondering what is a digital system? Is it only binary? Or decimal, octal, hexa are also digital system?
How about starting at the beginning.  What do you want to do?  Do you really want to do "computer engineering?"
Offline larsdenmark
« Reply #6 on: October 19, 2023, 10:17:36 am »
Make some projects with CPLDs or FPGAs.
E.g. using one of these boards:
https://www.kickstarter.com/discover/advanced?ref=nav_search&term=fpga
If you are into software you can make a simulator for logic boards.
Offline Swake
« Reply #7 on: October 19, 2023, 12:31:34 pm »
Simulators. Plenty of different stuff out there, from Arduino like things up till Spice.
When it fits, stop using the hammer
Offline rstofer
« Reply #8 on: October 19, 2023, 01:23:37 pm »
Analog computing!
This schematic is for MATLAB Simulink but the ideas are the same for other schemes.  The 1/s blocks are simple integrators with initial conditions as appropriate.  1 ufd and 1Mohm work well for low speed solutions.
The big idea is to get rid of differential terms by integration.
« Last Edit: October 19, 2023, 01:32:28 pm by rstofer »
Offline MrAl
« Reply #9 on: October 19, 2023, 01:47:37 pm »
You can delve more into theory.  For example, learn Boolean Logic.  We don't know what you have already studied however maybe you covered that already.  Then, look into Automated Reasoning.
Offline BILLPOD
« Reply #10 on: October 19, 2023, 06:07:24 pm »
Tation, HDL stands for high-density lipoproteins. :scared:
Offline jpanhalt
« Reply #11 on: October 19, 2023, 08:04:16 pm »
And VHDL must be very high density...  HDL is good for you.  What about VHDL?
