Author Topic: Building a pulse generator: puzzled by PCB trace impedance matching  (Read 3124 times)
Offline iMo
  • Country: pm
  • It's important to try new things..
Re: Building a pulse generator: puzzled by PCB trace impedance matching
« Reply #50 on: March 17, 2024, 01:18:25 pm »
MIC5205 - should not the BYP pin capacitor wired to its output (like 100pF for example) make the MIC5205's response actually faster?
Also you may try to impedance match the 12ohm (or whats ever) outputs of the CMOS drivers directly to the 50ohm connector with a pcb traces microstrip design as "the impedance transformer", without the output resistors there (the resistors have some parasitic L and C)..
Online shapirusTopic starter
  • Country: ua
« Reply #51 on: March 17, 2024, 01:40:07 pm »
Hm, maybe. I didn't try this, just followed the datasheet circuit, knowing that I can, as usual, fix stability issues with a fat electrolytic cap, if necessary :).
That's an interesting idea, but I need to do my research, and that'll be a different project, maybe as an exercise in designing a 4-layer board and ordering it at a fab house. This one is done with a straightforward approach of using series resistors.
Offline shabaz
« Reply #52 on: March 17, 2024, 03:50:43 pm »
Nice-looking board! And that selectable frequency is handy.
Even though I don't use the pulse generator much, it still comes in useful occasionally, as an extra signal source. I used it to test a DIY H-field probe by feeding it into a test microstrip. Also the edges are so sharp, you can use like the 101st harmonic etc., for crudely testing VHF receivers.
The following users thanked this post: shapirus
  • Country: ua
« Reply #53 on: March 17, 2024, 06:17:29 pm »
Nice-looking board!
Thanks. And that's a handmade board! The solder mask really improves the looks of it.
Yeah, that was the idea: make a small reasonably functional device for both learning and practical applications (which are still mostly for learning, as it's a hobby).
p.s. It emits sound at 1 kHz, 50% duty cycle output. Must be the microphonic (or rather the opposite) effect of the caps and maybe the board itself (I did VCC copper pour on the top layer). Ouch. And some instability at output high still remains, but I think I don't really care at this point. There's still room to add another 820 uF/6.3V cap, if I want to.
« Last Edit: March 17, 2024, 06:20:46 pm by shapirus »
  • Country: ua
« Reply #54 on: April 06, 2024, 10:38:38 pm »
I'm going to try to use a spectrum analyzer to estimate the edge speed of this pulser.
@tggzzz, what source of noise did you use in https://entertaininghacks.wordpress.com/2015/08/11/measuring-digital-signal-edge-rates-without-an-oscilloscope/ ? What shoud its frequency spectrum be: does it need to have uniform power distribution all the way into RF, or we only care about up to tens of MHz?
Offline tggzzz
« Reply #55 on: April 06, 2024, 10:59:18 pm »
Something cheap and nasty from fleabay.
The knee frequency and risetime are related as indicated. The noise source needs to have power above the knee frequency.
It is an approximate technique, and any vaguely competent noise source ought to be flat enough.
Make sure you don't overload the a spectrum analyser input; you may find a 200MHz high pass filter useful.
« Last Edit: April 06, 2024, 11:12:07 pm by tggzzz »
  • Country: ua
« Reply #56 on: April 06, 2024, 11:24:12 pm »
Yes I understand that this technique is approximate, that's why I used the word "estimate" rather than "measure".
Was wondering if my JDS2800 signal generator was suitable (it has noise as one of possible output waveforms), but apparently it won't do: its noise power nicely rolls off after 60 MHz, which, not so surprisingly, matches its max output frequency.
I'll try to find that Johnson's book for a more detailed explanation.
This is a rabbit hole indeed (but a welcome one). Since the most difficult part of creating a white noise generator seems to be finding a suitable high-frequency op amp, and it looks like I can obtain some of those locally, now I, naturally, want to try building one myself, especially now that I have an SA with which I can test its performance, rather than just buy a ready made one from Ali (even if they are sold for just $20-$25). That will likely turn out not as easy as it seems, but that's okay.
  • Country: ua
« Reply #57 on: April 06, 2024, 11:34:03 pm »
Actually... aren't we just testing the max switching frequency of the IC in question this way rather than the edges speed? They are of course related, in a way, but not quite directly.
Offline tggzzz
« Reply #58 on: April 06, 2024, 11:52:08 pm »
Not opamps; use RF MMIC amps.
They seem to be ~£12 on fleabay. Bg7tbl design, e.g. https://www.ebay.co.uk/itm/296127208776
  • Country: ua
« Reply #59 on: April 07, 2024, 12:09:26 am »
Yes, figured that out already. Can probably be done with discrete RF/MW transistors as well. I think I have some, but this is something that I'll rather build using ICs. For example, found one BGA616, seems to be suitable and can be had locally for about $1.5 apiece.
Ebay doesn't ship to Ukraine now, but that same stuff can be bought on Aliexpress. But price is not the point. $25 vs £12 or whatever makes no difference: I want to build the thing myself now, as it seems to be a perfect little project for experimenting with: cheap, simple in theory, low component count, easily measurable performance.
  • Country: ua
« Reply #60 on: April 28, 2024, 08:43:05 pm »
I have some curious results using a spectrum analyzer (TinySA Ultra) to see the spectral content of the generator's signal.
The interesting part is comparing it with another generator. I have assembled a quick and dirty pulse generator, or rather a pulse shaper, made of a single 1EDN7512 high-speed MOSFET driver.
I wasn't going to use it in this role, but I noticed that it had about 300 ps rise time (at a 0..15V transition) in spice simulation without load, so I thought hmm why don't I make a pulser out of it and see what happens. I don't expect it to behave exactly the same in reality, but it must still be pretty fast: a few ns turn-on time with a 1nF load is quite something.
Its typical output resistance is specified at below 1 Ohm, so I simply placed two parallel 100 Ohm resistors in series with the output, followed by an SMA connector. All mounted tightly on a small SOT-23-5 breakout board.
Now, the spectra I see in both cases don't look quite like what the textbooks say, however, I do think that I see the "second break" point on one of them, that's the point where the frequency is supposed to be equal to 1/(pi*Tr) (assuming Tr=Tf), and it meets the expectations I think.
Here's the 1EDN7512:
A very clear roll-off after about 470 MHz (~680 ps transition time), and it's dropping down pretty much into noise* after 600 MHz.
*Not sure if it can be called noise, because the actual noise floor (when there's no input) is at or slightly below -90 dBm.
But here's what the 4 x SN74LVC1G04 pulser produces:
Barely noticeable hump at ~510 MHz (that would be ~620 ps transition time) and a gradual further decline with no obvious steps, with the power levels at those higher frequencies staying above those of the other pulser.
Both had their fundamental frequency equal and set to 1024 kHz. Output levels were also the same. There was a 20 dB attenuator between the generator and the SA input in both cases.
Not sure what to make of it other than that the second pulser apparently has more energy in higher frequencies and that the first one's transition time can very likely be derived from the spectrum.
« Last Edit: April 28, 2024, 08:48:46 pm by shapirus »
