Author Topic: Building power supply for audio mixer  (Read 1450 times)
Offline FrankentronicsTopic starter
« on: February 12, 2020, 02:19:33 am »
Greetings,
I bought a used Alesis Multimix8 audio mixer without a power supply.
There is a 3 pin (I guess DIN) connector in the back with the following specs labeled next to it.
18VAC x 2
320mA x 2
The replacement power supply is about $50 and it says that there is a torodial transformer inside. I think the original "power supply" is in fact just a transformer (the PCB with rectifiers and voltage regulators is in fact inside the mixer).
Will the following transformer do the job, or will it overheat?
https://www.alliedelec.com/product/rs-pro/6719081/70647091/
But I'm guessing the following would be a better choice, right?
https://www.alliedelec.com/product/rs-pro/6719126/70647102/
Or can someone recommend an entirely different one?
Thank you, all, in advance.
"If you obey all the rules you miss all the fun."
- Katharine Hepburn
Offline MarkF
Re: Building power supply for audio mixer
« Reply #1 on: February 12, 2020, 02:33:04 am »
Either one would be okay.  Even the small one is twice your requirement.
  The small one is 0.8A per secondary
  The large one is 2.0A per secondary
The following users thanked this post: Frankentronics
« Reply #2 on: February 12, 2020, 03:08:00 am »
Oh, I see...
Thank you very much.
- Katharine Hepburn
Offline Jwillis
« Reply #3 on: February 12, 2020, 04:46:39 am »
Oh, I see...
Another place you could look at is https://www.antekinc.com/transformers/
They have really well built products as well.
« Reply #4 on: February 14, 2020, 03:39:27 am »
I rigged up a salvaged transformer and it seems to work.
" alt="" class="bbc_img" />
The salvaged transformer is not toroidal. Is there any reason why it should be toroidal?
Also, the salvaged transformer is rated at 17V - 0 - 17V. But I actually get 19V - 0 - 19V at full load.
Thanks...
- Katharine Hepburn
Offline Jwillis
« Reply #5 on: February 14, 2020, 04:46:08 am »
Thanks...
Not really . Toroidal are more efficient but you be fine with E core transformers. Your measurements are about right . The transformer is rated for 110V AC but your house Mains is 120V so the secondary will be about 19V . No worries about the extra voltage on the primary.
« Last Edit: February 14, 2020, 04:50:41 am by Jwillis »
