Good day everyone,
I need help trying to calculate the output voltage of a CLC/pi- Filter.
Firstly objective of the project-
I have a DC motor rated for 12V/1.2A which i would want to use to cut PCBs & as a small dremel.
The design
the design has the following.
Stage 1 - Stepdown transformer, 230Vrms/50Hz - 18Vrms/50Hz.
Stage 2 - Bridge rectifier - GBU6J (datasheet -
https://www.vishay.com/docs/88615/gbu6a.pdf)
Stage 3 - Filter to smooth out bridge rectififer output. (C Filter/ LC Filter /CLC Filter) - I have selected a CLC filter, as it has best of both C filter & LC filter.
Stage 4 - DC-DC stepdown converter using PWM.
Stage 5 - Output Stage.
I need help specifically in Stage 3, that is CLC Filter design.
Firstly what is an acceptable ripple voltage in this circuit?
Secondly, How does one design CLC-Filters, cascaded CLC-Filters as well.
How to calculate (Vout/Vin) or gain of these filters? I would like to write a C program to calculate gain & plot graphs using root.
