I was mistaken. 332 capacitor means 3300pF. so it's really Sullen and key of 6800pF and 3300pF with the LF411CP. This means low pass of less than 10kHz.
With 6.8n/3.3n the corner frequency is at ~4.7kHz (see attached screenshot).
Compare this to the original datasheet Sullen and Key 1 000pF and 220pF with cutoff of 50,000kHz. What does this do to the ripples? Does it mean the ripples at all frequencies will be less when the 50kHz cutoff is used versus the say 7kHz cutoff? Or does it mean only ripples below 7kHz would be cutoff in the latter?
I don't know what frequency the ripples have. The screenshot you provided was unclear because you cut off the units respectively the values of the time and amplitude scale.
If you use the 4.7kHz filter variant, the amplitude of the ripples that are
far above the corner frequency will be less compared to the 50kHz filter. Ripples
inside the filter passband can obviously not be attenuated at all.
Also more poles means more abrupt cutoff. What has this got to do with suppressing the ripples? Kindly explain because I want to understand the mechanism.
As already mentioned, you can only suppress ripples that are
outside of the filter passband. A steeper filter (more poles) ensures ripple voltage(s) with lesser amplitude.
It's just an amplifier. I don't need 50kHz but 7kHz may be too low for say audio use.
So 20kHz bandwidth will suffice?
