Consider this Sullen-Key low pass filter.
(Attachment Link)
If you change the amplifier to LF411CP (with the same pins). How much would the frequency response change?
When I increase the value of the capacitor from 1000pF to 6800pF, the frequency get lowered. Why is that?
I found a Ltspice file using the third order filter (see attached). I changed it to the 2nd order Sullen-key by deleting some parts and changing the values. Please check if the entry is correct. Also the voltage source is reverse. This is ok for AC, isn't it? Second. What amplifier is in the Ltspice attached Ltspice file?. How do you change it to the LF411CP? I want to see if the frequency response would change. If it's hard to change. Please change it to LF411CP and attached the edited Ltspice.
(Attachment Link)
(Attachment Link)
What does ".ac oct 20 10 10000" mean? If I removed it, I can't run the simulator anymore.
Thank you.
The most obvious answer is that this depends on the operating frequency vs the power bandwidth of the op amp.
The power bandwidth is a lower frequency number than the gain bandwidth product and that is because the slew rate comes into effect also.
If you do not want to calculate this then a very rough guide is to divide the bandwidth by 30 to 50.
For example, an LM358 has a gain bandwidth of 1MHz, but its power bandwidth is only around 30kHz with a 5v peak AC output.
It does depend on the output voltage amplitude too though, so if the output amplitude was lower the power bandwidth would go up.
If you choose a higher bandwidth op amp then it is not likely to alter the frequency response, but then you have to think about oscillations.
In short, op amps have their own frequency response and to know the effects of changing one out for another you have to do a few little calculations. The power bandwidth calculation is the most important or else you could get a lot of distortion on the output.
The maximum frequency for any or the usual op amps is:
Fmax=2*pi*A
where
A is the peak amplitude of the output voltage of the op amp in volts.
It's interesting that the peak output of the op amp is more important to know than the gain bandwidth product. That's because the slew rate is usually the limiting factor not the gain bandwidth product, and the slew rate works with the output amplitude in determining the max allowable operating frequency, so you also have to determine what your max output voltage peak will be.
