Author Topic: Can I use a capacitor balast for neon indicator bulb?  (Read 1158 times)
Offline ELS122Topic starter
« on: November 09, 2022, 05:23:09 am »
Why is it always a high resistance resistor used as a ballast for neon bulbs? wouldn't a small value capacitor do the same thing and be cheaper, and more reliable?
Offline jonpaul
Re: Can I use a capacitor balast for neon indicator bulb?
« Reply #1 on: November 09, 2022, 05:39:22 am »
not good practice, the cap will need a safety rating and pass line transients .
The neon lamps usually fail long before the tiny 1/2 w 100k resistor
j
Jean-Paul  the Internet Dinosaur
Offline chess
  • Country: cn
« Reply #2 on: November 09, 2022, 05:57:16 am »
resistor is more cheaper
Online Circlotron
« Reply #3 on: November 09, 2022, 06:01:50 am »
If your mains supply is a perfect sine wave with no noise spikes and you always managed to turn on your neon lamp at the voltage zero crossing a capacitor might be okay. If either of the foregoing occur your neon will likely blow up or fail some other way because noise spikes and turn-on transients are high frequencies that essentially pass straight through the capacitor. The neon will try and clamp the voltage across itself to about 60V or so, similar to a zener diode.
Online David Hess
  • DavidH
« Reply #4 on: November 09, 2022, 08:59:28 am »
When the lamp turns on during each half cycle, its negative differential resistance characteristic will draw a large current spike through the capacitor.
Offline wraper
  • Country: lv
« Reply #5 on: November 09, 2022, 09:11:55 am »
Film capacitors in capacitive droppers are way less reliable than resistors which are not overloaded.
Offline Zero999
  • 0999
« Reply #6 on: November 09, 2022, 01:12:55 pm »
Yes, this will shorten the life of the lamp and is why inductive ballasts were always used for gas discharge lamps such as fluorescent tubes.
Online David Hess
  • DavidH
« Reply #7 on: November 10, 2022, 12:17:00 am »
At high frequency using a capacitor as a ballast works because the lamp never shuts off, but at 50 or 60 Hz the lamp, or at least a neon lamp, has to restart on every cycle.
Offline vk6zgo
« Reply #8 on: November 10, 2022, 01:00:16 am »
The current draw of a neon indicator is so low, that a resistor doesn't need to have much of a power rating --capacitors will almost always be more bulky.
That said, I have used a capacitive dropper with an indicator lamp, but a LED,not a neon.
It wasn't off raw Mains, either, but a 65v AC control voltage from a transmitter.
Online Circlotron
« Reply #9 on: November 10, 2022, 01:41:48 am »
Could you use a xenon flash lamp in glow discharge mode, same as a neon? Mild source of continuous light, not bright like a flash?
Offline Zero999
  • 0999
« Reply #10 on: November 10, 2022, 08:16:20 am »
I've found some neon lamps light at such low currents, I can hold both wires and touch the outer sheath of a live wire with the glass bulb and it will flicker and glow dimly.
The starting voltage of a strobe is very high, so it would need a step-up transformer to run off the mains.
Online David Hess
  • DavidH
« Reply #11 on: November 11, 2022, 02:18:02 pm »
The resistor ends up dissipating about 50 milliwatts, but I always seem to end up using a 1/2 watt resistor for the extra voltage margin.
I think I tried using a capacitor once and the lamp just exploded.
