Hello, My kitchen hood (Teka) has stopped working.
I removed the board and found a damaged SS310 Diode.
The board is simple, it has the 220V AC that it converts to DC and then transforms into 12V for the circuit where the SS310 Diode was, this circuit has a ULN2003A that controls a few Relays:
I highlighted the Diode in the image above with a red line, as I don't have any
SS310, and just to test, I used an
SS14 i had here and the board turned on without any problem, the display and the relays also work.
The problem is that diodes have different characteristics, one is 100V and the other 40V as well as 3A to 1A..
Do you think it's better to buy an equal diode (100V-3A)? or can i leave this one? The current that passes through here doesn't seem to be much.. because (i assume) that this part of the circuit is just to control the ULN2003 and the relays.
P.S.: In my area, the closest i can find (of the SS310) is the SS510, 5A, 100V..
Thanks
